45's actually take away the DB's was either Alpine or skittlergood that did testing on it. Can't remember which.
Probably because the 45s most people use take up extra cuft. Instead of getting tight triangular shaped wedges that fit perfectly in the corner.
so what does that do besides take up space as well? Your logic isnt exactly going to help your argument.
It does take up space, but not nearly as much.
Example below.
so again whats your argument. you made the statement back it up.
I said probably, it was an assumption that made perfect sense in my own head.
Why do you have to be such a condescending prick about it?
New Setup;
H/U; Pioneer DEH-80prs.
Wiring; 2 runs of 2/0 OFC & Big 3.
Subs; 2 D1 DC Level 4s.
Monoblock; DC 3.5k.
4 Channel; JBL GTO1004.
Highs; Vifa NE25VTS-04.
Mids; Aura NS6-255-8A.
Alt; 160a.
Batts; Optima, KHC1800.
mainly because its one of those get loud myths CJ. While there could actually be some merit to the thought of eliminating corner angles no one knows at precisely what angle is going to actually help you. The degree of angle will come into play. Im not sure what retard started the 45s in the corners thing but the odds of slapping a piece of wood in the corner to cut down the angle and having it actually help are pretty astronomical.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Example below.
because you dont know what you are talking about but yet still trying to give advice. If you want to try to pull things out of your ass and try to present them as fact guess what? I'm going to call you out on it every time. dont get butt hurt because you got aired out. if you think that was condescending you havent seen anything.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Makes sense. I never use 45s in all corners, I only use a 45 in the corner of the box that leads into the port. That does make sense to me.
n8 is right the angel is the biggest factor while 45's anywhere in a box will hurt you 99% of the time a wammy as xs spl jeff calls it has helped more times than it has hurt
a wammy swallow angel bord that gos on the back wall and is pretty much the length of the back wall the highest part starts behind the subs and the swallow part gos to the port like a GIANT 45 but again small angle this only works with subs one one side and the port on the other will not work with middle ports
Edited by Team Bassick (ALPINE)
Example below.
Re-read my post, I wasn't giving advice. Go ahead, call me out on my probable statement.
I'm not butt-hurt & how did I get aired out?
It was condescending and I can really care less as to how much more condescending you can be.
New Setup;
Monoblock; DC 3.5k.
Alt; 160a.
Now one time that 45s can be useful are if you are looking to build a strong box but dont want to double ply the box. The 45s in the corners will make the box stronger if done properly.
Example below.
just stop while your ahead thats my advice to you
I was planning to end it after his next reply.
New Setup;
Monoblock; DC 3.5k.
Alt; 160a.
  • Who's Online   0 Members, 0 Anonymous, 2407 Guests (See full list)
