Sergeant_Skyrim Posted August 21, 2012 Report Posted August 21, 2012 Hey guys, I'm new to home audio so I've been reading around a bit and experimenting with leftover parts at home for the past couple of weeks. I'm finally getting my 10" XCON tomorrow and have a pair of 5.25s that I picked up and am wanting to use these together in a home application. Now my only problem is finding a receiver to power all of this and possibly more in the future. I have tried looking for something that won't overpower the speakers (40w RMS & 4ohm each) but will give the sub enough power (D2-ohm 1750w RMS ). I'm gonna be trying to make a T-Line for the sub and seeing how that works out at first so I'm not looking for THAT much power but still maybe a couple 100 watts. So basically I just need something that's 4-ohm & 8-ohm stable (all of the ones I find only give info for 8-ohm) and will dish out the kind of power that I'm looking for. I'm also looking for something that has appropriate crossover options for the sub and speakers. If anybody could help me that'd be great, again I'm new to home audio so if I'm not understanding something here let me know Build in progress
kalilac619 Posted August 21, 2012 Report Posted August 21, 2012 whats your budget? 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
Sergeant_Skyrim Posted August 22, 2012 Author Report Posted August 22, 2012 whats your budget? I don't have a limit per se, I know that it'll cost me if I want something good and reliable, but that being said I'm not looking to spend an arm and a leg. I was thinking maybe a couple $100? I'm trying to find something that has outputs for speakers and and output for a subwoofer where the outputs will give the sub more power and the speakers less power. Like a 5 channel car amp I guess you could say Build in progress
Slobalt7 Posted August 25, 2012 Report Posted August 25, 2012 My $100 Koss 5.1 does that but it would still way underpower your sub, 80 WRMS x 5 and 120WRMS for the sub... all @ 6 ohm though. Even underpowered the sub should still hit in the right box. I have a pair of xplod's (not mine) with 1200W max's in series on mine right now and they shake my whole apmt building... I am no longer allowed to play them anymore... For some good dedicated channels and for a couple hundred I would get a Harmond Kardon used, has more plugs on the back than your post count. Yeah, it's slower than your bowel movements.
412 CVX Posted August 25, 2012 Report Posted August 25, 2012 Receivers work more similar to a car head unit, rather than a car amplifier. you're going to want a separate amplifier for the sub amp. the receiver will have powered outputs for speakers. and rca outputs for your sub amp. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
Sergeant_Skyrim Posted August 27, 2012 Author Report Posted August 27, 2012 Receivers work more similar to a car head unit, rather than a car amplifier. you're going to want a separate amplifier for the sub amp. the receiver will have powered outputs for speakers. and rca outputs for your sub amp. Ohhhhhhh! Think I'm understanding this a bit better now then, I'd just get some RCAs to hook a plate amp up to the receiver and run the sub through that? That would make a lot more sense and be easier to do then Build in progress
