XS Power
Questions about another battery
Also, One more thing, Your system will be most likely hooked up to the back batt so it will need to constantly be charged by the front one, Which gets the power from the Alt thus putting another load on it, So pretty much in the end it should be evenly distributed between both.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
Urgent is to dont mix AGM´batts with lead acid batt´s.
Still a good deal, get 2 of those http://www.stevemeadedesigns.com/board/topic/144556-dont-seem-like-a-bad-deal/, with the saved money to XS you can
pay al the wires, fuses and so on for the install of the batt´s.
"in the abundance of water, the fool is thirsty" Bob Marley
Also be sure to do the big 3, Step that fuse up to a 300 amp since you would be running a 270 alt and the wire shouldn't be over 5ft or so. (Big 3 charge wire).
i was told a 250 would be fine so i need a 300 amp fuse for sure?
2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
​MB Quart Component Sets
Pioneer 5x4s
Audiotechnix Power Wire, Speaker Wire, Sound Deadener
DC Audio Level 4 10s
DC Audio 3.5k
Rocford Fosgate R400-4
HID 6k
Slammed Truck on 20s
Candy Blue.
well i guess since the alt is a 270 of couse i will need more lol dumb
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
Pioneer 5x4s
DC Audio 3.5k
HID 6k
Candy Blue.
Battery can be a smaller one if you want. I would get a xp3000 for the back and be done with it. As to hooking them up, It's as easy as connecting the positive to positive and negative to negative ( or a nice chassis ground in the back). Just make sure you fuse within 18" of front batt and 18" before the rear battery and you're good to go.
Question about that. To get all technical, if you connect the smaller one to the bigger one, what happens with the current? Like if you crank it to start the car, does the power come from the bigger one, or both? And the alternator charges which? I get what you mean about how to wire them, just wondering about the technical aspect of it.
running batteries in parallel such as how everyone does on here mean that the total amperage of each battery will be put together thus creating in a sense a much larger battery with more capacity. voltage will still stay the same on this kind of a circuit. if you connect the alternator to the front battery it will charge both batteries. in a sense it will push amperage through the first battery then the second and so on and so forth
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
but since your running a 3.5k i would look into a d3100
people who have bought from me Team Bassick (ALPINE) Purplehaze nidus
head unit sony dsx-s310btx
subs 2 12 incriminator audio king of bass
subs amp incriminator audio 20.1
mids/highs
mids/highs amp incriminator audio 6.4
equalizer clarion
crossover interfire
alternator 1 mechman 240amp
battery's xs power 1 d2100 2 d3100
sky high car audio 1/0 awg ofc wires
memphis car audio 1/0 ofc
xs power xs flex 4 awg
sky high car audio 8 gauge ofc
sky high car audio 12 gauge ofc
t spec rca
check out my building log http://www.stevemead...frey-build-log/
http://www.stevemead...d-other-things/
check out audio gear i have for sale
http://www.stevemead...51#entry1595151
  • Who's Online   0 Members, 0 Anonymous, 1330 Guests (See full list)
