sbg Posted August 23, 2012 Report Posted August 23, 2012 j/w about this, my friend has a xscorpion slotport box for 2 12s and is telling me that the shop were he got it told him that its 4 cb.ft. and tuned to 38hz and that all the subs that the shop has put in to box made a 3db increase lol im sure this is not true. but wanted to know if someone has info on this box.... Quote 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Joe X Posted August 23, 2012 Report Posted August 23, 2012 Measure the external dimensions as well as the port dimensions and then post those and people can tell you the real specs, having said that you don't want to use those prefab enclosures in most cases. Subs work best in enclosures designed specifically for them and solidly built. Quote
sbg Posted August 23, 2012 Author Report Posted August 23, 2012 Measure the external dimensions as well as the port dimensions and then post those and people can tell you the real specs, having said that you don't want to use those prefab enclosures in most cases. Subs work best in enclosures designed specifically for them and solidly built. i dont use a prefab ... i ask this because he tells me that his box is as good as mine and its a prefab........but his setup does sounds just as good. im going to text him and get the specs....... Quote 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted August 23, 2012 Author Report Posted August 23, 2012 Measure the external dimensions as well as the port dimensions and then post those and people can tell you the real specs, having said that you don't want to use those prefab enclosures in most cases. Subs work best in enclosures designed specifically for them and solidly built. 14'' h 17''d 32'' w --- port is 11 3/4'' h 3 1/2'' w but has a 1/2'' board in the midd of the port to split the sub up so like 1 1/2'' w on the port for each sub.... this is what he said. Quote 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Joe X Posted August 23, 2012 Report Posted August 23, 2012 Measure the external dimensions as well as the port dimensions and then post those and people can tell you the real specs, having said that you don't want to use those prefab enclosures in most cases. Subs work best in enclosures designed specifically for them and solidly built. 14'' h 17''d 32'' w --- port is 11 3/4'' h 3 1/2'' w but has a 1/2'' board in the midd of the port to split the sub up so like 1 1/2'' w on the port for each sub.... this is what he said.14 x 32x 17 gives a gross internal volume of 3.42 less if there is a double baffle and to that you have to take away sub and port displacement, so NO 4 cubes net possible. And you are not giving the centerline length of the port or the port parts length so can't calc tuning. Quote
sbg Posted August 23, 2012 Author Report Posted August 23, 2012 Measure the external dimensions as well as the port dimensions and then post those and people can tell you the real specs, having said that you don't want to use those prefab enclosures in most cases. Subs work best in enclosures designed specifically for them and solidly built. 14'' h 17''d 32'' w --- port is 11 3/4'' h 3 1/2'' w but has a 1/2'' board in the midd of the port to split the sub up so like 1 1/2'' w on the port for each sub.... this is what he said. 14 x 32x 17 gives a gross internal volume of 3.42 less if there is a double baffle and to that you have to take away sub and port displacement, so NO 4 cubes net possible. And you are not giving the centerline length of the port or the port parts length so can't calc tuning. what he sent me today lol Quote 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
412 CVX Posted August 23, 2012 Report Posted August 23, 2012 the opening is 1.5" and the back part is 2"... well that's not right! Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
ear2ear Posted August 23, 2012 Report Posted August 23, 2012 Are those all inside port dimensions? Some of them do not add up. Quote '09 Sierra Ext Cab - under construction (1) RF T2500-1 -running- (4) RF T1 12's (1) RF T1000-4 -running- (2) RF T1652-S Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800 Buncha OFC Knu Buncha Second Skin Kenwood DDX814 - Alpine Imprint - RF 360.3
sbg Posted August 23, 2012 Author Report Posted August 23, 2012 lol idk like i said its not my stuff its a friends that thinks his prefab box is the best box u can get ... and i was j/w what its tuning was... but it seem he cant use a measure tape lol Quote 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Joe X Posted August 23, 2012 Report Posted August 23, 2012 What subs are going in that enclosure? Quote
