xscorpion prefab slot port for 2 12s
j/w about this, my friend has a xscorpion slotport box for 2 12s and is telling me that the shop were he got it told him that its 4 cb.ft. and tuned to 38hz and that all the subs that the shop has put in to box made a 3db increase lol im sure this is not true. but wanted to know if someone has info on this box....
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Measure the external dimensions as well as the port dimensions and then post those and people can tell you the real specs, having said that you don't want to use those prefab enclosures in most cases. Subs work best in enclosures designed specifically for them and solidly built.
i dont use a prefab ... i ask this because he tells me that his box is as good as mine and its a prefab........but his setup does sounds just as good. im going to text him and get the specs.......
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
14'' h 17''d 32'' w --- port is 11 3/4'' h 3 1/2'' w but has a 1/2'' board in the midd of the port to split the sub up so like 1 1/2'' w on the port for each sub.... this is what he said.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
14 x 32x 17 gives a gross internal volume of 3.42 less if there is a double baffle and to that you have to take away sub and port displacement, so NO 4 cubes net possible.
And you are not giving the centerline length of the port or the port parts length so can't calc tuning.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
the opening is 1.5" and the back part is 2"... well that's not right!
More box builds
I'm with captain stupid.
Are those all inside port dimensions?
Some of them do not add up.
'09 Sierra Ext Cab - under construction
(1) RF T2500-1 -running- (4) RF T1 12's
(1) RF T1000-4 -running- (2) RF T1652-S
Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800
Buncha OFC Knu
Buncha Second Skin
Kenwood DDX814 - Alpine Imprint - RF 360.3
lol idk like i said its not my stuff its a friends that thinks his prefab box is the best box u can get ... and i was j/w what its tuning was... but it seem he cant use a measure tape lol
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 1283 Guests (See full list)
