(2) Immaculate Sundown Audio Z v.3 18's Dual 1
1. Product:
Two (2) Sundown Audio Z v.3 Dual 1 Ohm Subwoofers
2. Specs:
Manufacture Sundown Audio
Motor Type Overhung
Driver Size 18 "
Driver Weight 60 lbs
Coil Diameter 3 "
Coil Material AL
Manufacture's Xmax 30 mm
MSRP $480 USD
Year 2012
TS Parameters (Measured by Data-Bass.com)
Qts 0.427
Qes 0.469
Qms 4.75
Fs 30.3 Hz
Res 1.7 Ω
Le 1khz 4.51 mH
Sd 0.115 m2
Vas 110.7 liters
Mms 458.4 grams
Cms 60 μm/N
BL 17.8 Tm
BL2/Res 186.4 N2/W
L/R Time Constant 2.65 milliseconds
SplSens 90.04 dB
3. Description/Condition:
9/10 Condtion
10/10 Mech
I say 9 out of 10 condition simply because I do not have the sundown trim panel piece that goes around the rim because I did not use and threw it away. A quick call to sundown can get you a new set. These were installed in a 4th order built and installed by Bassheads ENT and were never abused. The only signs of use are from mounting. other than that there is no damage. I bought brand new and Used for approx 2 months.
I have original shipping boxes from Sundown Audio that these will be shipped in.
4. Price: :
650.00 + actual shipping firm for both OR if you're local to central Florida I can work out a cash deal picked up.
5. Pictures:
bump
man,..... (ive been watching) your "giving" away some killer gear,.......
Mod's,. im sorry to "tire kick"
OP.... im sorry for any reason your doing what you feel you need to do,...
better luck to you man..... really......
Thanks, I'm just moving on to different things. The amps and batteries I had listed sold in a few days. These 18's are proving to be a bit tricky.
Edit: please PM me if you want to get a hold of me faster as it sends a notification to my email when I have a pm, but not when I have a reply in the thread. Sorry for the delay
