cboos55 Posted August 25, 2012 Report Posted August 25, 2012 I have 1 15" Fi SSD subwoofer. i plan on using a 4 ft^3 box with 1 4" flared precision port. the tuning calculator i used said i need 6" of port length for a tuning of 33 hz. i would like to know if 1 4" port is enough for this sub and also if the calculator is right on the 6" of length. thanks My 1992 Blazer Currently: - 3" Body Lift - 32" Cooper tires on Center Line Rims - 2 15" FI SSD's - 6 cubic foot box tuned @ 29 hz - 2 Hitron 2000.2 for subs - 1 sony 4 channel for speakers - 2 runs of 0 guage to back - 270 amp alt - Custom center console Soon: - 4 15" FI SSD's - 2 Hifonics Brutus 2400.1D - 2 Hifonics Zeus 40.4 - Custom door panels - Custom battery rack - Many other goodies:) (Not the best stuff but its what i can afford)
8ight Posted August 25, 2012 Report Posted August 25, 2012 4" is waaaaaaaaaaay too narrow, not enough port area at all. As far as the calculator, I cannot say. I'm gonna hate
CleanSierra Posted August 25, 2012 Report Posted August 25, 2012 No, 1 4" port will not be nearly enough port area for that amount of airspace. I'm thinking a couple of 6" ports or a few 4" ports would be the way to get the port area in the desired amount. That's without me running ANY numbers, but I know for sure, 1 4" aero will not get it done. Im not the one you want to try to troll. Just a fyi for you.
cboos55 Posted August 25, 2012 Author Report Posted August 25, 2012 its hard for me to get more ports in the box due to where it is located i could do a 6" port though would that be any better. im looking for sound quaity if anything My 1992 Blazer Currently: - 3" Body Lift - 32" Cooper tires on Center Line Rims - 2 15" FI SSD's - 6 cubic foot box tuned @ 29 hz - 2 Hitron 2000.2 for subs - 1 sony 4 channel for speakers - 2 runs of 0 guage to back - 270 amp alt - Custom center console Soon: - 4 15" FI SSD's - 2 Hifonics Brutus 2400.1D - 2 Hifonics Zeus 40.4 - Custom door panels - Custom battery rack - Many other goodies:) (Not the best stuff but its what i can afford)
cboos55 Posted August 25, 2012 Author Report Posted August 25, 2012 if 6" port isnt enough how big or should i say smaller the box should be in order to allow a 6" aero port to work and sound good My 1992 Blazer Currently: - 3" Body Lift - 32" Cooper tires on Center Line Rims - 2 15" FI SSD's - 6 cubic foot box tuned @ 29 hz - 2 Hitron 2000.2 for subs - 1 sony 4 channel for speakers - 2 runs of 0 guage to back - 270 amp alt - Custom center console Soon: - 4 15" FI SSD's - 2 Hifonics Brutus 2400.1D - 2 Hifonics Zeus 40.4 - Custom door panels - Custom battery rack - Many other goodies:) (Not the best stuff but its what i can afford)
412 CVX Posted August 25, 2012 Report Posted August 25, 2012 6" will be better, but it's still on the small side. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
Guest Posted August 25, 2012 Report Posted August 25, 2012 if you cant bend a circle port around inside the box, you can always do a slot port
cboos55 Posted August 25, 2012 Author Report Posted August 25, 2012 the way i planned it was to do a sleek custom box in my truck and port it directly into the cabin of my car using an aero port. seen and heard it done and loved it. i could go down to 3.5 ft^3 the sub i believe needs about 3.25. would a 6" still be too small for that size box? if not what length tube due i need to tune to 33hz? My 1992 Blazer Currently: - 3" Body Lift - 32" Cooper tires on Center Line Rims - 2 15" FI SSD's - 6 cubic foot box tuned @ 29 hz - 2 Hitron 2000.2 for subs - 1 sony 4 channel for speakers - 2 runs of 0 guage to back - 270 amp alt - Custom center console Soon: - 4 15" FI SSD's - 2 Hifonics Brutus 2400.1D - 2 Hifonics Zeus 40.4 - Custom door panels - Custom battery rack - Many other goodies:) (Not the best stuff but its what i can afford)
CleanSierra Posted August 25, 2012 Report Posted August 25, 2012 1 6" port will still not be enough port area. Roughly with the space you have, 3 4" ports at full length would be the right way to go. Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted August 25, 2012 Report Posted August 25, 2012 What dimensions do you have you're using on the box? As previously stated a slot port may be the best route for you. The slot port eats into your box volum however. You did mention that you have a pretty specific idea of what you want which I totally understand. SQ won't happen if the box doesn't have proper port per square foot. So you need to figure out where adjustments can be made to give that sub the proper amount of airspace and port area. Im not the one you want to try to troll. Just a fyi for you.
