towing with 2000 3.3 grand caravan
I have a 2000 grand caravan with the 3.3 and am wanting to use it to tow my boat. Its probably around 1200lbs. I know that they have weak trannies but 1200lbs is a relatively light load. I believe its rated for 1800lbs with no tow package. Anybody tow with a caravan?
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
I just did some quick research and it appears that you should be able to tow that weight. How big is that boat? 1200 seems light. But then again my parents travel trailer weighs 11,500 pounds unloaded and the truck is rated for around 16k. So maybe it's just light from my point of view. Haha
Big 3 with Yellow Top
Its a 16ft aluminum boat. Boat motor and trailer are around 1,000-1200lbs
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
I believe you have the same motor and tranny that was in my 95, so you shouldn't have problems.
And i put my shit to hell and back, and it held all the shit i've done to it.
( That includes, burnouts, offroading x3 times, once was snowy, and was fine. )
Grandpa has a a 98 or 96 with the 3.3, and he tows with it.
Assuming the only difference is the body, you should be fine.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
Alright thanks, i know the motors are good its just the transmission I've heard so many bad thing about them
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
If 1200lbs is like 400-500 KG, that shouldnt be a problem. In holland we are allowed to tow (if the vehicle is rated for it) 750 kg's. Typical dutch engines are like 1.3 - 2 liter gas engines. We tow this all the time with a 1.9 TDi engine without any problems. Most cars are manuals.
I have no clue what the kg weight would be. I know the 3.3 would handle it fine its mainly the transmission im worried about. Right now i tow with a 4.3 blazer and it does fine. It just has alot of miles (double what my van has). I live in LA so theres no hills or anything. Longest tow would be about 30 miles one way
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
kg's is lbs / 2.204263. that will get you close. Just multiply kg's X 2.204263 for lbs. I do this all the time at work. If your van downshifts a lot on the hills i would recommend not using overdrive. Automatic overdrives get hot quick when pulling weight.
Absolutely take it out of overdrive. Do that when you tow anything.
  • Who's Online   0 Members, 0 Anonymous, 1770 Guests (See full list)
