Can I wire my volt meter to my amp turn on switch so my volt meter turns on with my amp?
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
U could or make it easier and use the h/u wires.
reading voltage at the amp itself is better than reading from the headunit.
unless you mean tap into the remote wire at the headunit harness and not run 3 whole wires from the amp in the back to the front of the car.
Thanks guys, I'll prolly just wire it to the headunit since mine has 2 remotes for some reason, just wanted to make sure.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
you mean power antenna and remote turn on? the blue wire and blue/white wire?
whether you do it at the amp or at the HU, the turn on comes from the same place... (unless you use the ignition wire which you arent)
I mean tap into the remote wire, and yes it's the power antenna wire, but it's not hooked up to anything. There's no remote for my volt meter (cheap chinese one, only power and ground) so i would run another like from my power on my volt meter to either the headunit or the switch for my amp. understand what im tryin to say?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
my amp is connected to a switch, so it doesnt come on with the car, it comes on when i want it to
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
wire it to the amplifier bro!
  • Who's Online   0 Members, 0 Anonymous, 945 Guests (See full list)
