Went out and bought a relay today to wire up my volt meter. Can someone explain to me, in lamens terms how to wire one up. A picture may actually just be the easiest.
P.S. I have my remote wire wired to a switch to turn my amp on and off
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
4 pin relay?
yes, 4 pin relay, thanks for the info. And just for clarification, i can hook pin 86 up to ignition OR accessory?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Pin 86 just gets hooked up to any switched power source. Ignition acc/on position, head unit remote, a separate switch, it doesn't matter. As long as it is switched on and off how you want it. Very useful for custom headlight harnesses, AC power inverters, cooling fans, or running multiple amps on a single remote line without stressing the remote line on the head unit itself. If you add diodes in the mix you can make some neat things happen.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
thanks man, that was very helpful and simple. exactly what i was lookin for (:
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
What is the gain or purpose of using a relay for the remote wire to an amp?
to not stress out the remote wire. or in my case, my volt meter has no remote, so i need a relay so that it doesnt stay on all the time.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
