Dj Drake Posted August 29, 2012 Report Posted August 29, 2012 I have a 2002 nissan frontier, here's a picture of it "not mine, just a picture I got off google" And I have 2, 15'' kicker comps, Peak Power: 500 Watts RMS Power: 250 Watts Impedance: Single 4 Ohm I also have a 1500 watt monoblock amp. The specs of this amp is: Monoblock Phantom amplifier with MOSFET power supply Delivers 1500 Watts at 2 ohms; 700 Watts at 4 ohms Low-pass variable crossover; 18dB bass boost What I need to know is, do I have the best amp for these subs, and if i'm going to get a new box what kind of box do I need to look for and what size. Also I'm using the shitty walmart wiring kit, does that effect anything? As you can tell I'm not a genius with this stuff.
ILoveBass21 Posted August 29, 2012 Report Posted August 29, 2012 is the amp rating in rms? peak doesnt mean anything
Dj Drake Posted August 29, 2012 Author Report Posted August 29, 2012 Idk man, this is the amp. http://www.amazon.com/PH1500M-Phantom-Mosfet-Monoblock-Amplifier/dp/B0032FOKSS
ILoveBass21 Posted August 29, 2012 Report Posted August 29, 2012 you can for sure get better results with an amp that does real rated power. what it your budget for the amp?
Dj Drake Posted August 29, 2012 Author Report Posted August 29, 2012 Doesn't really matter the price, because no matter what it is I'm having to save up anyways. Just dont suggeset a warhorse haha
ChevyBoy95 Posted August 29, 2012 Report Posted August 29, 2012 350rms at 4 ohms is what it does, but then again probably not. you are asking if this amp is the best for the subs, well, a 64dollar amp should be a red flag in the first place, not to mention "1500 watts." How about get a kicker dx500 to go with the kicker comps. http://www.sonicelec...-11DX500.1.html does perfect power for the rms of the comps, and should power them great, plus kicker amps are pretty stout. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
HunterJohnson Posted August 29, 2012 Report Posted August 29, 2012 you could get that or I have this amp for sale http://www.stevemeadedesigns.com/board/topic/148938-fs-skar-15001-amplifier-290-shipped-obo/ which is rated 1500rms at 12v's I would recommend running a 1/0 quality wiring kit to a 1500 watt amplifier. such as this kit http://www.knukonceptz.com/productDetail.cfm?prodID=IXOS-PK0 Good luck man! Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
ChevyBoy95 Posted August 29, 2012 Report Posted August 29, 2012 you could get that or I have this amp for sale http://www.stevemead...90-shipped-obo/ which is rated 1500rms at 12v's I would recommend running a 1/0 quality wiring kit to a 1500 watt amplifier. such as this kit http://www.knukoncep...prodID=IXOS-PK0 Good luck man! way too much for him power wise. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Dj Drake Posted August 29, 2012 Author Report Posted August 29, 2012 Will I be able to tell a difference with that amp? Like will they sound better? or maybe louder?
ChevyBoy95 Posted August 29, 2012 Report Posted August 29, 2012 Will I be able to tell a difference with that amp? Like will they sound better? or maybe louder? boss vs. the kicker? yes and yes. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
