Enclosure for 1968 vw bug. Need help on port sizes
Daniel Shepard
got a 68 vw bug and want to put two ma-8 skar 8"s in the rear cargo area. This is what I figured up on sizes. At .75 wood thickness I came up with 3.14 cubic feet before displacement. These dimentions are EXTERNAL. Can someone double check me? Also I need help figuring out the port, size and displacement being that the top is angle slightly. I want a slot port firing up tuned to 33-34hrz, subs inverted. I can shrink the length if need be but everything else needs to stay the same. Weird shapes throw me off, Any help is appriciated!
Ill have to check it out. Ill do a build log once i get some help here. I should have plenty of room for these two 8s ported 1.2cuft isnt much, just the port that will take up the majority
I checked your volume in CAD real quick.
With 3/4" wood the internal area of that profile is 152.24 sq in
34.5" inside = 3.04 cu ft internal gross
'09 Sierra Ext Cab - under construction
(1) RF T2500-1 -running- (4) RF T1 12's
(1) RF T1000-4 -running- (2) RF T1652-S
Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800
Buncha OFC Knu
Buncha Second Skin
Kenwood DDX814 - Alpine Imprint - RF 360.3
with an angled baffle, you cant bend the slot port if you put the port on the front of the box. which will not really allow you to tune lower.
  • Who's Online   0 Members, 0 Anonymous, 624 Guests (See full list)
