qcbangin Posted September 3, 2012 Report Posted September 3, 2012 I can't believe this is possible, but... I have a 91 Lincoln towncar. 0/1 run front to back into a fuse, and a. 4 gauge from fuse to a hifonics Zeus 500.2 bridged @4 ohms. Big 3 done, stock 95amp alt. and whatever size battery a towncar takes (it is huge, tho). Here's where it gets funny. I checked my voltage @ the amp with my dmm, while music is playing, and car is idling, and voltage reads 15.3! With car off voltage @ amp is 14.3. I know it can't be possible, but its what my dmm is telling me. I checked the dmm on another cars battery, and on my ohms setting, and it read right. What do you guys think? I'm gonna post pics too.
KenC210 Posted September 3, 2012 Report Posted September 3, 2012 your dmm is broken i had one that told me i was at a higher voltage then i bought a new one and it was corrected edit: what kind of dmm is it? Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
qcbangin Posted September 3, 2012 Author Report Posted September 3, 2012 the first pic the car is off. the second pic is on.
qcbangin Posted September 3, 2012 Author Report Posted September 3, 2012 your dmm is broken i had one that told me i was at a higher voltage then i bought a new one and it was corrected edit: what kind of dmm is it? it's in the pic. i don't really remember the exact brand off hand.but if the dmm is broke, why is reading right on a totally different car. on the other car, with nothing done to it, it idles at 14.1 and sits at 13.8 with car off?
rockFord_Expedition Posted September 3, 2012 Report Posted September 3, 2012 What do you mean exactly when you checked the DMM on another cars battery on "your ohm setting" DMM should just be set to read DC voltage period. Maybe you meant something else. Did you try disconnecting both positive and negative cables from your battery and testing it that way? It sounds like you have never messed with your battery if you aren't sure what it is. Did you purchase the car used? It is possible but bnot likely that someone put a 14V battery in there. Just a thought until we get more info. Something is probably wrong with the meter Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
TylerParrish Posted September 3, 2012 Report Posted September 3, 2012 Maybe the other car's number's are also higher on than mulitmeter than they actually are, I would say try testing with a different multimeter if you can. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
rockFord_Expedition Posted September 3, 2012 Report Posted September 3, 2012 Maybe the other car's number's are also higher on than mulitmeter than they actually are, I would say try testing with a different multimeter if you can. X2 Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
KenC210 Posted September 3, 2012 Report Posted September 3, 2012 What do you mean exactly when you checked the DMM on another cars battery on "your ohm setting" DMM should just be set to read DC voltage period. Maybe you meant something else. Did you try disconnecting both positive and negative cables from your battery and testing it that way? It sounds like you have never messed with your battery if you aren't sure what it is. Did you purchase the car used? It is possible but bnot likely that someone put a 14V battery in there. Just a thought until we get more info. Something is probably wrong with the meter i missed where he said it was ohms setting.... yeah it should be at dc voltage, check that you have everything correct then try again... if its at dc voltage at you still get a high number like that your dmm is messed up Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
qcbangin Posted September 3, 2012 Author Report Posted September 3, 2012 What do you mean exactly when you checked the DMM on another cars battery on "your ohm setting" DMM should just be set to read DC voltage period. Maybe you meant something else. Did you try disconnecting both positive and negative cables from your battery and testing it that way? It sounds like you have never messed with your battery if you aren't sure what it is. Did you purchase the car used? It is possible but bnot likely that someone put a 14V battery in there. Just a thought until we get more info. Something is probably wrong with the meter i didn't mean i checked the battery with the ohm setting. i checked my sub with the ohm setting. i didn't disconnect the battery yet because its too dark out already. i haven't changed the battery since i got the car 4-5 months ago. got it from my wifes gma when she passed. so before me, she was the only owner. she bought it brand new in 91. the car has always been serviced by a lincoln dealer, so i doubt they put a 14 volt battery in it. but, maybe.
rockFord_Expedition Posted September 3, 2012 Report Posted September 3, 2012 What do you mean exactly when you checked the DMM on another cars battery on "your ohm setting" DMM should just be set to read DC voltage period. Maybe you meant something else. Did you try disconnecting both positive and negative cables from your battery and testing it that way? It sounds like you have never messed with your battery if you aren't sure what it is. Did you purchase the car used? It is possible but bnot likely that someone put a 14V battery in there. Just a thought until we get more info. Something is probably wrong with the meter i missed where he said it was ohms setting.... yeah it should be at dc voltage, check that you have everything correct then try again... if its at dc voltage at you still get a high number like that your dmm is messed up I changed the text color where he says it I can't believe this is possible, but... I have a 91 Lincoln towncar. 0/1 run front to back into a fuse, and a. 4 gauge from fuse to a hifonics Zeus 500.2 bridged @4 ohms. Big 3 done, stock 95amp alt. and whatever size battery a towncar takes (it is huge, tho). Here's where it gets funny. I checked my voltage @ the amp with my dmm, while music is playing, and car is idling, and voltage reads 15.3! With car off voltage @ amp is 14.3. I know it can't be possible, but its what my dmm is telling me. I checked the dmm on another cars battery, and on my ohms setting, and it read right. What do you guys think? I'm gonna post pics too. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
