n8ball2013 Posted September 4, 2012 Report Posted September 4, 2012 box is on the small side and port is on the low side. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Kidder Posted September 4, 2012 Author Report Posted September 4, 2012 box is on the small side and port is on the low side. it sucks building in a regular cab :/ it also sucks being a noob. but as always, your input is appreciated. thank you.
n8ball2013 Posted September 4, 2012 Report Posted September 4, 2012 you can probably get away with it but as you start adding port to your box you are going to eat up internal space. may want to do some aero ports instead if you are dead set on a 15 in a reg cab. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Kidder Posted September 4, 2012 Author Report Posted September 4, 2012 you can probably get away with it but as you start adding port to your box you are going to eat up internal space. may want to do some aero ports instead if you are dead set on a 15 in a reg cab. Already have the equipment, picked the woofer up brand new never seen power for 100 bucks, couldn't pass it up. I got the box a little bigger and the tuning closer to the 33 34 range, but can get the port area per foot up.
n8ball2013 Posted September 4, 2012 Report Posted September 4, 2012 i would worry less about lowering the tuning and more about port area per foot. your original tuning frequency is perfectly fine. Even if it wasnt an AQ and capable of playing below tuning with authority it would still be fine. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Kidder Posted September 4, 2012 Author Report Posted September 4, 2012 i would worry less about lowering the tuning and more about port area per foot. your original tuning frequency is perfectly fine. Even if it wasnt an AQ and capable of playing below tuning with authority it would still be fine. Okay, still playing with numbers. Thanks again!
Jordan Guess Posted September 4, 2012 Report Posted September 4, 2012 what dimensions do you think you could expand? edit: try this, i expanded all of your external dims by 1 inch and got MUCH better results. height=21 width=18 depth=27 port height=3 port width=16.5 port length=30 same displacements and common walls and what not.
Kidder Posted September 4, 2012 Author Report Posted September 4, 2012 what dimensions do you think you could expand? Width is the only thing really set in stone. Can't go any bigger on that. If anything I'd rather add height. My 4 wheel drive is electronic but not push button, the t-case shifter is on the floor so length would probably be best kept around 26".
Kidder Posted September 4, 2012 Author Report Posted September 4, 2012 I think I'm getting a little closer..maybe?
