caraudiolove Posted September 4, 2012 Report Share Posted September 4, 2012 Link to comment Share on other sites More sharing options...
CleanSierra Posted September 4, 2012 Report Share Posted September 4, 2012 Not enough port area per foot. Needs to be at least double that. Make the port wider, plus remove the port dimensions from the "diameter" box. That box is only used when using aero or round ports. You need it blank for a square or L-port. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
CleanSierra Posted September 4, 2012 Report Share Posted September 4, 2012 Plus I don't think you need to double baffle for those subs. That box you entered .75 in, is if you want to add a double layer on the baffle. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
Joe X Posted September 5, 2012 Report Share Posted September 5, 2012 If you want a small box use a single 6" aero port. Link to comment Share on other sites More sharing options...
caraudiolove Posted September 5, 2012 Author Report Share Posted September 5, 2012 How much port area do i need? Link to comment Share on other sites More sharing options...
Autruche Posted September 5, 2012 Report Share Posted September 5, 2012 What are your maximum dimensions? Personally I'd try for ~3.5 - 4 cubes net and ~60 square inches (or three 4" aeros if you'd want) of port total, tuned to 32-35. Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want Link to comment Share on other sites More sharing options...
caraudiolove Posted September 5, 2012 Author Report Share Posted September 5, 2012 Link to comment Share on other sites More sharing options...
caraudiolove Posted September 5, 2012 Author Report Share Posted September 5, 2012 is this design any good or better Link to comment Share on other sites More sharing options...
CleanSierra Posted September 6, 2012 Report Share Posted September 6, 2012 The last box dimensions you posted, where is the port located in the box? If it is an L-port that makes a turn when it gets to the back of the box, and then runs parallel to the back wall, your common port walls should be "3". If I were you, I'd follow what Artruche said, and go with a few aero ports. Try a few 3" or 4" ports to see if you can get the port area per foot higher. With a slot port(the design you're currently playing with) you would want a minimum of about 12 inches per cubic foot of airspace. For round or aero ports go for 8-12 sq inches of port per cube of airspace. You're doing just fine though, keep plugging numbers and you'll find a box that will work. Port area for your airspace is really important. If you don't supply the proper amount of port, you COULD get port noise or have a sub that sounds like its in a leaky sealed box, rather than a ported box at all! Hope my post was helpful, sorry it took a little while to respond. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
caraudiolove Posted September 6, 2012 Author Report Share Posted September 6, 2012 would 40.50 square inches be good for the port 3" wide and 24'' be good? Link to comment Share on other sites More sharing options...
