i was looking at getting dual 2's and wiring to .5 for my next build, but then i looked closer and it said the dual 2's were actually dual 1.4's, so does that mean the amp would be seeing .35 ohms?
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
you sir are correct. you can go .35 or 1.4
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
you sir are correct. you can go .35 or .7
:ninja:
Thanks, might just do 1.4 then, I can always wire back down if box rise is outrageous.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
:ninja:
Thanks, might just do .7 then, I can always wire back down if box rise is outrageous.
yeppers... i run .35.. good luck mang.. when doing your box use bolts for the terminals so its easier to wire down if you want
:ninja:
:ninja:
:ninja:
I'm like 4 steps ahead of you, I've used bolts as terminals from the beginning :P how much more stress does .35 put on the amp than .5?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
I don't think you can wire to .7 with that coil config
Parallel would be .35 ohms
Series-parallel would be 1.4
So you would be stuck at 1.4 ohms as I certainly wouldn't recommend .35 daily
.35 would be last resort for if I'm getting like 2+ohms box rise.
How much of a difference is there from .5 to .35? Seems like it could actually be quite a bit.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
pwnt
:roflmao:
:ninja:
good job..
:ninja:
never even crossed my mind that i could only get .7 if i was only running one. Glad that awkward conflict was avoided
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
  • Who's Online   0 Members, 0 Anonymous, 912 Guests (See full list)
