Mlcantin Posted September 5, 2012 Report Posted September 5, 2012 Does anyone know if wiring one jl audio 13w7-Dual 1.5 ohm can be wired to one ohm on an amplifier? And if so does anyone know where i can find a wiring diagram?
REVOofRustler Posted September 5, 2012 Report Posted September 5, 2012 With a d1.5 you can get a nominal .75 ohms. You do that by wiring all positive (both sub terminals and amp) together, and all negative terminals together. With box rise you may even end up at 1 ohm. Hope this helps! 2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant - Fi and Crescendo - Stock Bose System - http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota 136.4 Sealed @ 29hz 137.0 Drivers window open @ 26hz
Mlcantin Posted September 5, 2012 Author Report Posted September 5, 2012 With a d1.5 you can get a nominal .75 ohms. You do that by wiring all positive (both sub terminals and amp) together, and all negative terminals together. With box rise you may even end up at 1 ohm. Hope this helps! I don't know of any amp that has a .75 ohm power rating
REVOofRustler Posted September 5, 2012 Report Posted September 5, 2012 What kind of amplifier do you have? If you have an amp that's stable at 1 ohm, you could probably pull off .75 ohms as long as you have the electrical to back it up. 2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant - Fi and Crescendo - Stock Bose System - http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota 136.4 Sealed @ 29hz 137.0 Drivers window open @ 26hz
08tahoe Posted September 5, 2012 Report Posted September 5, 2012 You can only wire it to .75 or 3 ohms
SlamminBeats Posted September 5, 2012 Report Posted September 5, 2012 With a d1.5 you can get a nominal .75 ohms. You do that by wiring all positive (both sub terminals and amp) together, and all negative terminals together. With box rise you may even end up at 1 ohm. Hope this helps! I don't know of any amp that has a .75 ohm power rating quite a few can run at .75
sbg Posted September 5, 2012 Report Posted September 5, 2012 With a d1.5 you can get a nominal .75 ohms. You do that by wiring all positive (both sub terminals and amp) together, and all negative terminals together. With box rise you may even end up at 1 ohm. Hope this helps! I don't know of any amp that has a .75 ohm power rating lot of amps will run .75 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
