2 Fi Bl 10's box design. *Think i finally got 'er right!*
TylerParrish
The port area per foot can be a good guess if your box is the size for 10"s but now has the net volume for many 12"s!
It's 20 not including the front mounted baffle, so 20.75 and i changed it back to the total length of the port being 14 inches so that i have a 6" clearance
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
I'm not sure how without raising te tuning to 37 Hz and or higher, which is too high for my taste.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
looks nice.. though there is no bracing on the back wall..
Might double baffle the back as well, but it's hard to brace with the slab of plexi right there
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
i think you will be fine with the box size as long as you set your subsonic filter properly.
well I'm trying to tweak the box now to make it as close to factory spec as possible with the tuning i want and the right amount of port.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Keeping your exact same baffle size just adding some depth a box can be made in a way there is no port extension to block your view inside and can tune low. Everything falls in to place when you drop in two twelves instead of two tens, take a look:
Updating...
i can see a few reasons why not to go with that idea. even with bracing in there, it's way too big and it would still be tuned higher than 34 Hz
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
  • Who's Online   0 Members, 0 Anonymous, 2479 Guests (See full list)
