removing unwound coil in magnet gap?
dblovah51
I'm pretty sure anything solid with a hook atleast should help, ideas to try after work, or the sub will b in the trash lol
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
Plastic pick will be best. anything metal just makes it a pain because you are dealing with a giant magnet. Have fun. it usually takes me anywhere from 30 min to 2 hours to get the coil out when this happens.
Sounds weird, but see if you can go to your local beauty shop or something and find some small, plastic or brass tweezers. Small enough to fit in the gap, but unnaffected by the magnet.
wow and i thought i worked slow!!!
done this a few times with a metal o ring pick took me 5 to 10 mins tops each time
ps i also get a Q tip with rubbing alcohol and wipe down the inside of the motor to get the burnt grime and smell out of the motor befor a recone... before i use to to this some freash recones would smell like burnt coils frist time played this is something a you dont want to smell on a fresh sub
  • Who's Online   0 Members, 0 Anonymous, 2258 Guests (See full list)
