big 3 question
I have a jl 1000/1 pushing a 1200 rms 15 built by team psi. I have a yellow under hood and in trunk (only cause I get them cheap) and my volts are dropping to 11.5 while full tilt. No system sitting at 13.7 to 14.0. I also have a 2 fared cap. I looked at a diff amp cause I heard my amp pulls a lot from alt. Stock alt also. I am wanting to do the big 3 this weekend but wondered if it would pull my volts up noticeably and if cap is also a factor in low volts. Another yellow in trunk. Can't afford a ho alt?
is that 11v when you're idling? i hope to god you're not playing full tilt while idling. cause thats fucking idiotic to do with a stock alt.
do the big 3, and get rid of the cap.
are you using 4 gauge wiring right now?
With all the money you probably spent on the caps and batteries, you could have a good H/O Alt. Yes the big 3 will help you, and like #3, take out the caps.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Hey I go full tilt at idle with a stock alt, only until I drop under 13v lool
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
yes. a new alt is the only way to get higher voltage. anything under 12.6-ish means that your alt is being used 100% and your stereo/whatever is now draining the batteries as well.
  • Who's Online   0 Members, 0 Anonymous, 865 Guests (See full list)
