got my rims looking like new!
so ive been doing research online to see if i can fix my rims which the previous owner didnt take care of at all. i love to keep my truck clean and this has been bothering me for months. the rims are boss 330 24inch the aluminum lip was very oxidized and stained instead of the aluminum shine it should have. i had heard wet sanding would work but never had the guts to actually try it. i found a couple other forums online explaining how the proccess goes and decided to finally try it out.
i used 600, 800, 1000, and 2000 grit wetodry sandpaper and used mothers aluminum polish the total cost was about 30 dollars. real cheap way to make them look like new
heres how the rims used to look
to sand these i used the jack to raise the truck. once i was ready i just turned it on put in on drive to have the wheels spinning
i started with the 600 grit and moved my way up. the longer and more patient you are the better they will come out
here is the rim after the 600 grit
this is the 800 grit
1000 grit after this you start seeing some of the shine to come out
2000 grit
now they are nice and smooth last step is to polish them up :D
heres half the rims with some polish to compare the difference
-2000 chevy tahoe 5.3 liter v8
-two DC audio level 3 15 inch subwoofers
-2 pairs of infinity kappa 60.9cs components
-rockford fosgate t1500.1bd for subs
-rockford fosgate t400.4bd for mids and highs
-alpine deck
-big 3 upgrade 0 gauge power cable
-optima yellow top battery
-custom made subwoofer enclosure 6 cubic feet tuned at 35hz
rims look good, I bet if you went with an even thinner sand paper you could get more detail out of them.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
it probably would have. this was my first time trying this but overall i am pleased with how they came out..100x better than they used to look jaja
-alpine deck
done that to some of my wheels before, i used water while sanding it helped out alittle. def makes them look alot better :good:
Nice work on the rims.
I need to do something like that to mine soon.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Nice work, I used that proces to polish aluminum parts, works perfect.
Did you apply a protective layer on top of the naked metal afterwards?
Woofer: 12" Phase Linear Aliante Limited
Mids & highs: DLS Ultimate 5 1/4"
Amp: Audison VRX 6.420
HU: Sony CDX-C90R
thanks you really should if your rims are oxidized its so worth it
-alpine deck
Lookin' good, clean wheels clean car!
-alpine deck
it works really good..i added a wax over the polish to help protect them longer so far its been about 3 weeks and havent had any issues :)
-alpine deck
