Alpine CDA-9886 SOLD!!
1. Product:
Alpine CDA-9886
2. Specs:
(Think everyone knows this unit by now)
http://www.alpine-us.../view/cda-9886/
CEA-2006 Power Ratings
  • CEA-2006 Power Rating: 4 I? @14.4V Ƈ%THD+N, S/N 80dBA (ref.1W into 4 I?), 18W x 4
Max Power Output Ratings
  • Max Power Output: 50W x 4
FM Tuner
  • Tuning Range: 87.7-107.9 MHz
  • Mono Usable Sensitivity: 9.3dBf (0.8 A?V/75 ohms)
  • 50dB Quieting Sensitivity: 13.5dBf (1.3 A?V/75 ohms)
  • Alternate Channel Selectivity: 80.0 dB
  • Signal-to-Noise (S/N) Ratio: 65.0 dB
  • Stereo Separation: 35.0 dB
  • Capture Ratio: 2.0 dB
AM Tuner
  • Tuning Range: 530-1,710kHz
  • Usable Sensitivity (IEC Standard): 22.5/27.0 (A?V/dBf)
Disc Player
  • Frequency Response: 5-20k A?1 dB
  • Channel Separation (at 1kHz): 85dB (at 1kHz)
  • Dynamic Range (at 1kHz): 95 dB
  • Total Harmonic Distortion (at 1kHz): 0.008% (at 1kHz)
  • DAC Type: 24-Bit DSP with integrated DAC
  • Wow & Flutter (%WRMS): B.M.L.
  • Oversampling: 8x/352.8kHz
  • Signal-to-Noise Ratio: 105 dB
Connection for iPodA?
  • MP3 Decoding: MPEG-1/2 AUDIO Layer-3
  • WMA Decoding: Windows Media' Audio
  • AAC Decoding: ACC-LC format ''/m4a'' file
  • Number of Channels: 2-Channel (Stereo)
Sound Tuning
  • Subwoofer Level Adjustment: -15dB to 0dB (1dB steps)
  • Bass Level Control Range: A?14dB at 100Hz
  • Bass Center Frequency: 60/80/100/200Hz (Selectable)
  • Bass Band Width Adjustment (Q): 4 choices (1 =narrow, 4 =wide)
  • Treble Level Control Range: A?14dB at 10kHz
  • Treble Center Frequency: 10k/12.5k/15k/17.5kHz (Selectable)
  • MediaXpander Modes: FM, CD, XM, MP3, (Level 1, 2, 3, Off), DVD Video (Level 1, 2, Off), DVD Music (Level 1, Off), (PXA-H100 Required)
  • MediaXpander Aux Settings: MP3, Music, Movie, (Level 1, Off), (PXA-H100 Required)
  • Equalizer: 5 Band Parametric (20Hz - 20KHz, 1/3 oct. Steps), 7 Band Graphic, (PXA-H100 Required)
  • Time Correction: Adjustable 6 Ch. Time Correction (L-F/R-F/L-R/R-R/L-SW/R-SW), (PXA-H100 Required)
  • Crossover: High Pass: 80/120/160Hz (Selectable)
  • IMPRINT: IMPRINT Sound System Ready (PXA-H100 Required)
Remote Control
  • Remote Control: Included
  • Model Number: RUE-4202
  • Battery Type: AAA Batteries (2 pcs.)
  • Dimension (WxHxD) mm : 42mm x 121mm x 23mm
  • Dimension (WxHxD) in : 1-21/32'' x 4-25/32'' x 29/32''
  • Weight: 1.5kg (3lbs. 4oz.)
Dimensions
  • Din Size: 1
  • Chassis Size (W x H x D) mm: 178mm x 50mm x 160mm
  • Chassis Size (W x H x D) in: 7'' x 2'' x 6-1/4''
  • Nose Piece Size (W x H x D) mm: 170mm x 46mm x 24mm
  • Nose Piece Size (W x H x D) in: 6-3/4'' x 1-13/16'' x 15/16''
General
  • Power Requirement: Power Requirement: 14.4 (11-16) V.DC
  • Pre Output Voltage (Before Clipping): 4V
  • Operating Temperature (A?C/ A?F): 60 A?C (140 A?F) to -10 A?C (14 A?F)
  • Maximum Mounting Angle: 35A? from Horizontal
  • Weight: 1.6kg (3lbs 8oz)
FEATURES
Tuner
  • Memory Presets: Preset Stations (FM:12/AM:6)
  • Memory: Auto
  • Seek Mode: Local/DX Selection
HD RadioA?
  • Built-In or Ready: HD Radio Ready
  • Connection: Alpine TUA-T500HD Required
  • Status Indicator: HD Radio Satus Indicator
  • Signal Switching: Automatic Digital/Analog
  • Multi-Casting: Multi-Cast HD1, HD2, HD3
BluetoothA?
  • Parrot Bluetooth Module Built-In: Bluetooth Ready
  • Connection: Alpine KCE-300BT Required. Features may differ between phone model and service providers.
  • Hands Free: Hands Free Calling
  • Phone Book: Phone Book Transfer
  • Streaming Music: Streaming Music Playback
  • Streaming Music Control: Streaming Music Control
  • Connection Type: Full Speed Connection for iPodA?
  • Connection for USB: Dedicated iPod Source
  • Connection: Full Speed Cable Included (KCE-422i)
  • Compatibility for iPodA?/iPhoneA?: Full Speed Connection: iPhone, 4th/5th Gen. iPod Video/Photo, iPod mini, iPod nano and iPod touch
  • M.I.X. (Shuffle) Capability: Song, Albums, All
  • Music Control: Song Up/Down/Repeat
  • Available Selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer, Audiobook
  • Percentage Search: Percentage Search
  • Information Display: Artist, Song, Album
  • Easy Navigating: Quick Search
Satellite Radio
  • Built-In or Ready: Satellite Radio Ready
  • Connection: SIRIUS or XM Adapter Required
  • Satellite Provider Capability: SIRIUS or XM
  • Preset Memory: 3-Bands (6 Per Band, 18 Channels Total)
  • Easy Navigating : Quick Search
  • Music Information: Category, Artist, Song
  • Portable Compatibility: SIRIUSPlug N Play Devices (Adapter Required)
Disc Player
  • Disc Type: CD Player
  • Disc Playback Type: CD/CD-R/CD-RW
  • Music Playback: MP3/AAC/WMA Playback
  • DAC: 24-Bit DSP with integrated DAC
  • Zero data Mute: 0 Bit Mute
  • Digital Servo: Digtal Servo
  • Music Sensor: Scan/Repeat
  • Playback Control: Play/Pause/Forward/Back
  • M.I.X. Mode: One (Folder)/All (Random Play)/Random (CD Only)
Sound Tuning
  • Subwoofer Level: Subwoofer Level Adjustment
  • Equalizer: 5 Band Graphic / 7 Band Parametric Equilizer Ready (PXA-H100 Required)
  • Bass Level: Bass Level Adjustment
  • Bass Center Frequency: Bass Center Frequency Adjustment
  • Bass Bandwidth Adjustment: EQ Width Adjustment
  • Treble Level: Treble Level Adjustment
  • Treble Center Frequency: Treble Center Frequency Adjustment
  • Loudness: Loud Feature
  • MediaXpander: MediaXpander Ready (PXA-H100 Required)
  • Time Correction: 6 Channel Time Correction Ready (PXA-H100 Required)
  • Crossover: High Pass Filter Adjustment
CD Changer Control
  • M.I.X.: One/All (Shuffle)
  • Multi-Changer Control: Multi-Changer Control including MP3 Changer CHA-S634 (with KCA-410C)
  • Music Text Information: CD:Text Scroll Display, MP3: Text Information Display (ID3 Tag)
  • Music Control: Play/Pause/Forward/Back
  • Repeat: Song/Disc
General
  • Power Output: 50W x 4 High Power Amplifier
  • CD Changer: CD Changer Control
  • Display: 2 Color Biolite Display
  • Control Type: Rotary Encoder Knob
  • Face Color: Gunmetal Black
  • Illumination Buttons: Blue
  • Playback: MP3/AAC/WMA Playback
  • USB Input: USB (1.1/2.0) Input (Mass Storage Class)
  • PreOut: 3 PreOut
  • BluetoothA?: Bluetooth Ready
  • Auxiliary Input: Versatile-Link Ready (KCA-121B Auxiliary Input)
  • Steering Wheel Control: Steering Wheel Control Ready
  • Selectable Power Input: 2 PreIn (Front/Rear)
  • Bass & Treble: Bass & Treble Controls
  • Fader & Balance: Fader & Balance Controls
  • Clock: Built-In Clock
  • DIN Trim Plate: Detachable Trim Plate
  • Detachable Face Plate: Detachable Face Plate
  • Dimmer: Dimmer Input
  • Power Antenna Lead: Power Antenna Output
  • Remote Turn-On: Amplifier Remote Turn-On Output
  • Audio Interrupt: Audio Interrupt Input
  • Mute: Built-in Audio Mute
  • Remote Control: Remote Control Included
Documents
3. Description/Condition:
8.5/10 cosmetic, 10/10 mechanical, I've had this for around 3 years, zero problems, only reason for the 8.5 is very small surface marks from use, and the markings for skip forward/back are wearing off (see pictures below), this includes all original cables, remote, faceplate holder and paperwork/manual
Also have the iPod adapter (KCX-422TR) needed to charge newer iPods, will include for 10 dollars
4. Price:No clue what these go for so I'll start at $175
5. Pictures:
This shows the markings I mentioned before
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
if u still have this tomorrow, or later tonight, will u do $150 shipped to 54758? i gotta get going to work, so pm me or w/e when u get this :) we can negotiate if u want.
Alex
Feedback Thread: http://www.stevemeadedesigns.com/board/topic/152368-littlebuck1919s-feedback/#entry2177586
i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
6/18/82 - 4/17/12
R.I.P. to my sister Shana
