Started out on here as nothing, and now its ehhhh something.
got some tint. hated the fishbowl
got some wood.
made the LMFAO robot head, decided its a bit heavy for a human neck, so i put it in the wagon,
took out the rear seats and made a floor.
then i braced it,
cut some trim panels,
got some carpet and some gay ass kickers.........
then won this cool trophy at the MECA event for being first place in modified 3 class :) 138.0 db @ 40hz with TERRIBLE electrical. voltage was dropping to 10.8:rolleyes:
batteries and real subs to come soon.
8.2 cubes @ 32hz
My old Build Log!
http://www.stevemead...der-in-a-jetta/
Two Obsidian 15s V2
Two Audiopipe Apsm 1500s
Fourth Order Wall
TEAM CLEARLY LOUDER
TEAM OBSIDIAN AUDIO
how much power? i know those comps really couldnt take much
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
mtx 1501d @ 2. the subs are my buddies. i cant decide what subs i want now, i was set on obsidians but then decided to hold off and now im between AB hd1s and Obsidians............
My old Build Log!
Two Obsidian 15s V2
Fourth Order Wall
TEAM CLEARLY LOUDER
TEAM OBSIDIAN AUDIO
just curious cuz he said he was dropping to 10 volts lol
Team NWSPL
baaudio Build Log
yeah i have bad electrical issues. i have done the big three, but stock 90A alt and one stock batt wont do the trick. picking up batteries next weekend, then ill work on gettting some decent subs. budgets suck.
My old Build Log!
Two Obsidian 15s V2
Fourth Order Wall
TEAM CLEARLY LOUDER
TEAM OBSIDIAN AUDIO
Not a bad score. My wall took a lot of tweaking tofinally get where I wanted. With good electrical on same gear you may get a 40 out of it
Team NWSPL
baaudio Build Log
I see lots of gains to be had with tweeks. How many cubes is the box? How much port area are we looking at? Simple things like having the sub holes with routered edges on the inside and routered holes for the cutouts themselves could yield a higher number from the TL. NOT carpeting the box could possbily get a better number. What frequency did it get that score at. Is it confirmed that it's the loudest frequency with that current setup? Was it a burp or was the score on music. I guarantee even as it sits there are tricks to get more out of her :)
Good luck with the rest of your build. Your skills will come around, and keep at it. The amount you learn build after build will amaze you.
