XS Power
I would throw the yellow top away and put an xs power bat up front. I'm no expert, but just knowing that the more guts the battery has the better it can perform, optimas have a lot of hollow space with that 6 pack looking design. Just my opinion. And I also "heard" you shouldn't mix battery types.
Mixing batteries isn't the worst thing you could do, but it is heavily frowned upon. The reason is, say you have a lead acid up front and a XS in back, the float voltage of the stocker up front wants to sit at 12.4V and thhe XS sits at 13.1V. The XS will slowly discharge into the stock to bring its voltage up and brings the XS down til they reach a point of equilibrium. Also, the two batteries have different modes of charging. It slowly reduces the life of the AGM batts, but by how much it damages that battery and shotens the lifespan I do not know.
Edited by Lbox88
unless you want to replace amps. dont do .5 n that electrical
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Replace the yellow top with an XS of the same size under the hood and add a d3100 in the back. This will take care of your desire to run at .5 ohm and will leave room for your expansion plans later.
When it comes to electrical, there is no such thing as overkill.
  • Who's Online   1 Member, 0 Anonymous, 434 Guests (See full list)
