Did you bypass anything factory with the new charge lead? Do you have a Honda?
I'm gonna hate
Did you replace the factory wiring or piggy back ontop of it?
Probably due to the increase in voltage. You said you did neg to chassis and chassis to motor.... I assume you mean bat neg to chassis etc......
Bat light probably nothing to worry about but as a side note to your big 3, you should go from alternator to case to frame also.
would piggy backing on top of the wire do more harm than good? im about to do the big 3 myself and was wondering if i need to take out the original wiring, or piggy back it?
When possible, your big 3 should always suppliment and not supplant the OEM wiring. In other words, add to the stock stuff, don't replace it.
  • Who's Online   0 Members, 0 Anonymous, 1204 Guests (See full list)
