LBM`s GroundPounder - LBM 15 x 4;RF T2500.1x 4, Termlab ->160+db !!!
Hi everyone, I am from India and here Car Audio scene is very bad. There are very few good installers here and very few have proper know how to make things happen. Anyways earlier I had a small setup which you people appreciated very much here is the link of the same. The thread was started by BITLD
http://www.stevemead...md18s-in-india/
List of Equipment
  • Source -> Kenwood KOS-A300
  • Processor -> Alpine PXA - H 701 With controller
  • Amp for High +mids -> Rockford Fosgate T600.4 x 2 nos
  • Amp for Subs -> Rockford Fosgate T2500.1 x 4 nos
  • Highs -> Rockford Fosgate PP4-T Punch Pro 1.5" 4-Ohm Tweeter x 4 nos
  • Mids -> Rockford Fosgate PPS4-6 Punch Pro 6" 4-Ohm Midrange x 6 nos
  • Subs -> SMD 18 inches #59 and #60
  • Alternator -> Mechman 220 amps
  • Batteries -> Northstar NSB 170 (about 600 ah combined )
  • Wiring -> welding copper cable 0/1 and 0/2 runs with copper busbars
  • Rca -> Sommer cable with Neutrik Connectors
  • Enclosure -> 1 inch MDF with lots and lots of Reisn (approx 15-18 kgs with 5 kgs glass...solid as rock)
The equipment !!!
So this time it is a complete rebuild. The earlier car was sold off as it was very old and started to show its age. So I got another. Here are the pics of the same in which the setup will be installed.
Covered the hood top and boot with vinyl !!!
Also the a-b-c pillars were also vinyl-ed. Got it done by a shop Auto Image in my city !!
One more thing I forgot to add before !!! The weight of the ride !!!
1010 KGS (this is before the install will weight it again when the Install will be complete !!)
More to come !!!
Ok then, the first upgrade the HO alternator. I have the Mechman 220 amps alternator so plan to use it for the time being, will add another when the setup is complete. Planned to use approx 10k+ rms this time. I know this alternator would be a bottle neck for the same but still....here are few pics...
The stock one was 70 Amps only...
The both alternators.
The sizes were a little different so had to machine the arms to make the alternator fit...here are few pics of the same...
Machining being done to match the stock alternator dimensions
The other side !!
The machining was done on a FLOOR BORING MACHINE !!!
Cover after machine.
After assembly !!!
0/1 gauge wiring connected !!
The location !!!!!
Installed !!!
Checked , up and running !!!!
All the removal , dis-assembly and re-assembly, re-install was done myself !! Except the machining for that I had the machine operator. Also the whole install will be done by myself like Steve does !!! He is my biggest inspiration !!!!
Next up is the front battery bus bar. I will be putting the battery bank in the back of the car and will disconnect the front battery. Here are few pics of the same !!!
The way I got the car pathetic is the word !!!
I had the old bus bar lying around so plan to use them !!!
A quick fix to mount it on the battery !!!
Installed.
Will be removing the thimble and will put the wire directly when the runs from the front to the battery bank will be made...
Stay tuned... more coming up !!!!!
looking great.... doing some nice work on that metal bhai !!!
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
The car interior stripped !!!
Continue....
Base size check !!!
Base installed..Could not more bolts in the front because of the fuel tank underneath. Will hold it from the front at the later stage
Rear wall mounting support !!!
The enclosure will be filled with resin and lots of it to make it strong !!! and inspired from here !!!
are you putting 4 15's or 4 18's in that lil car...........and dont think it matters which one. its gonna be crazy.. good work man
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
tuned in !
I want to see that poor little Swift !
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
