HunterJohnson Posted September 16, 2012 Report Posted September 16, 2012 Here's the plan sundown ZV3 12" in a scion tc 2006 hatch back. Currently I have sa-12's in a 4.4 net with aero ports tuned to 28hz and this peaks at 39hz which I love. New design is AMP: SAZ3500 Subs: Sundown Zv3 12" D2 Wiring: 2ohms daily, .5 ohms for shows Heres the box: Here's the specs off torres: The port will be on the passenger side of the car and the specs are 3.5 net and tuned to just at 30hz or without the second baffle 3.7 net and tuned 28.7x hz. I can add the baffle on top and keep it at 3.7 net. Let me know what you guys think your experience on these subs thanks! Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
Phototini_xB Posted September 16, 2012 Report Posted September 16, 2012 Looks to be very similar for the box I am designing for two Skar ZVX-12's I want to put in my Scion xB. 2012 Scion xB Build- http://www.stevemeadedesigns.com/board/topic/150000-2012-scion-xb-temp-build/
roscoe1129 Posted September 16, 2012 Report Posted September 16, 2012 y side port? Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
HunterJohnson Posted September 16, 2012 Author Report Posted September 16, 2012 y side port? That's how groundpoundercustomz designed it. And I foud out that in a scion tC it's best to do the port to the passenger side. Currently my box is two aero ports in the center tho. Also I was reading to put subs next to each other to avoid any cancelation that may happen Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
ear2ear Posted September 17, 2012 Report Posted September 17, 2012 So your picture shows port back, but you're doing port side? In other words the port opening is on the 21" side? Or is the picture correct? Port back, but on the passenger side of the vehicle... One thing, you need to check "subs up" in Torres. This is most important if entering multiple baffles. If the port opening is on the 21" there is another change to make in torres. '09 Sierra Ext Cab - under construction (1) RF T2500-1 -running- (4) RF T1 12's (1) RF T1000-4 -running- (2) RF T1652-S Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800 Buncha OFC Knu Buncha Second Skin Kenwood DDX814 - Alpine Imprint - RF 360.3
HunterJohnson Posted September 17, 2012 Author Report Posted September 17, 2012 So your picture shows port back, but you're doing port side? In other words the port opening is on the 21" side? Or is the picture correct? Port back, but on the passenger side of the vehicle... One thing, you need to check "subs up" in Torres. This is most important if entering multiple baffles. If the port opening is on the 21" there is another change to make in torres. it is port BACK, i thought it meant on the side of the box. Port back on the passenger side. Picture would be right but it would be the mirror image. Not quite sure what you mean by subs up. Also what do you mean by port on the 21" sorry??? Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
ear2ear Posted September 17, 2012 Report Posted September 17, 2012 Since you confirmed the picture is correct yet mirrored, ignore my question about the port being on the 21" side. See the 2 boxes you can check below the miscellaneous section? Your subs are facing upward so you need to check that box. The program needs to know which face to account for extra baffles. By the way - since you didn't enter an extra baffle, you're port height should be 11". '09 Sierra Ext Cab - under construction (1) RF T2500-1 -running- (4) RF T1 12's (1) RF T1000-4 -running- (2) RF T1652-S Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800 Buncha OFC Knu Buncha Second Skin Kenwood DDX814 - Alpine Imprint - RF 360.3
HunterJohnson Posted September 17, 2012 Author Report Posted September 17, 2012 Since you confirmed the picture is correct yet mirrored, ignore my question about the port being on the 21" side. See the 2 boxes you can check below the miscellaneous section? Your subs are facing upward so you need to check that box. The program needs to know which face to account for extra baffles. By the way - since you didn't enter an extra baffle, you're port height should be 11". Oh that makes sense let me edit that and I'll update this thread Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
HunterJohnson Posted September 17, 2012 Author Report Posted September 17, 2012 so with the subs facing upwards I'm looking at 33.4hz and net 3.33 cubes with 1 extra baffle. Without the baffle is stays the same but accounting for a new 11" port it would be 30.23hz and a net volume of 3.6 Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
