who wants to help design a box for me ( i suck lol)
Nate Futuristic
downloaded a box calculator app on my galaxy nexus (failed)
torres calculator- after messing with it a few times trying to adjust the port and over all displacement i cant ever get the tuning right (.gif
im also worried a little but about imp rise so i want any tips to help lower it but not making the box "peaky"
(adding 45s? resin? bolts in the box? depth of the woofer? anything that may help)
(this is a daily system so i understand i cant really fight it to much without making the box peaky or rebuilding box after box)
i also need a reputable box designer to come up with something "unique" and stylish p.gif
common chamber?
separate chamber? (what are the negatives/gains)
im almost certain im going to go with slot over aero ports (with 45s and round port edges to help air flowzzzz)
i want it to hit the lows more than anything (decaf is pretty much all i listen to)
subs are 2 vvx 12s (dual 2s wired to .5 ohm and yes i know the risks lol)
12 vvx specs taken from skaraudio.com
Re : 3.8 ohms
Fms : 22.1 Hz
Res : 101.8 ohms (holy fuck?)
Qms : 4.57
Qes : 0.45
Qts : 0.41
Rms : 10.0 kg/s
Cms : 0.16 mm/N
Mms : 330.8 gr
Nref :0.14%
Bl : 19.8 n/a
SPL : 83.3 dB
Vas : 59.2 L
Rp : 33.3 ohms
Lp : 60.0 mH
Cp : 1126.1 uF
Le : 3.37 mH
Rms : 600 Watts
2.5" Voice Coil
enclosure recommendations
1.1 ft^3 (sealed)
1.5-2.0 ft^3 (ported)
0.15 ft^3 (displacement)
7" ( depth)
12.5" (OD)
11-1/8" (COD)
amp is aq2200d
this is going to be walled of in the trunk of a 00 mustang
in a ideal world with low box rise i would like to give these lil guys at least 800-1000 rms daily
max box dimensions are 34-35 inches wide (thats still giving it an inch or so on each side of the wheel well)
hight max is 14 inches (nothing more! im cutting metal to get this!)
depth is 25-26inches (giving plenty of room for batteries and amp(s) )
34-35x14x25-26
pm or post if you have any other questions!
donation will be given on design quality D.gif ( meaning blueprints and proper building specs for me to build it not just a torres screen shot with a google image)
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
Shoot me a pm, I love designing boxes and using sketchup. Plus I've got a bit of experience with your subs and car.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
still need this!!!!
tyler made me a design but its around 4.5 cubes after DIS
im pushing these with a 2200d so i assume i need the box a bit smaller
anyone?
where is buck box designs?
or 412CVX lol
O_O
i promise i wont blame you if the port is in the wrong spot!
no one wants moneyz!?!?!?!?!?!?!??!?!?!?!?!
*cough* *cough* Ram-Designs *cough* *cough*
man id really like to avoid it but i sent a request....
Ram was on here for some time, he has some sweet designs. Plus you said "reputable box designer to come up with something "unique" and stylish"
yea but i can see it taking awhile for him to come up with something
i need it quick
otherwise im doing a fart box with 2 8" areos lawl
1.75 each, center port, lots of port area. I need your max dim's. PM me.
And no fucking 45's.
pmd
  • Who's Online   0 Members, 0 Anonymous, 2258 Guests (See full list)
