molina425 Posted September 18, 2012 Report Posted September 18, 2012 I have a 2012 dodge ram 1500 sport.just added a system consists of Jvc headunit 2-Alpine type r 12" swr-12d4 Hifonics brz2400.1d amplifier Ported foxbox I had it all wired at 1 ohm. And ended up blowing a sub.just got my new sub replacement thru warantee and want to hook it back up at 1ohm to push the subs hard.but am worried one might blow again.i think it blew because the gain and other setting werent set correctlymy question is if anyone can help me n tell me where i shud set everything at as far as settings on my amp.want 1 ohm to push subs hard and at 4ohms its not strong enough.any help is greatly appreciated.thinking i might be clipping but not sure.just think it was all set wrong.please help me out.thank you for any assistance.
bigmescan Posted September 18, 2012 Report Posted September 18, 2012 what are your settings at the moment? SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
Endgame Posted September 18, 2012 Report Posted September 18, 2012 That's a whole lot of amp for that sub.You may want to get another R to help eat that power. Trust No One
Lbox88 Posted September 18, 2012 Report Posted September 18, 2012 That's a whole lot of amp for that sub.You may want to get another R to help eat that power. It's only 200Wrms extra per sub, it's possible. Where in West MI are you btw? UBL | Build Log
molina425 Posted September 18, 2012 Author Report Posted September 18, 2012 Bigmescan- at the moment everything is at 0.because im not gna put them back in until i can figure iut the best way to set all my settings on the amp to not blow another sub. Endgame-I have 2 subs already.each sub is 1000 watts rms.so the 2400 watt amp shud be plenty for em. Lbox88-each sub is rated at 1000Wrms.not 200.and im not in west MI.im in Texas. Amp is 1 ohm stable so i deffinetly wna take advantage of that and have it wired at 1 ohm.so just need recomendations on where to set it all at.
TylerParrish Posted September 18, 2012 Report Posted September 18, 2012 lol at some of your reading fails xD but no bass boost, gain should be set to whatever your headunits rca outs are, ans subsonic should be about 5 Hz below box tuning and low pass betweent 60 Hz-80 Hz. Do u know what your box is tuned to? or what tuning even means? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
molina425 Posted September 18, 2012 Author Report Posted September 18, 2012 Tyler parish-my box specs say port tuning at 35 hz.thats all the info as far as tuning goes on it. And honestly no i dont know 2 much about all of that type of information. Normally i just go to a shop and have it all done.but with ny job i hardly have any spare time to drive a few hours away to the ckosest audio shop.
Lbox88 Posted September 18, 2012 Report Posted September 18, 2012 Good reason to learn how to do it at home. UBL | Build Log
molina425 Posted September 18, 2012 Author Report Posted September 18, 2012 Good reason to learn how to do it at home. Thats why i installed my setup with help from a few buddies.im also doing alot of research to try n learn as much as i can.
Watch the bass Posted September 18, 2012 Report Posted September 18, 2012 http://www.stevemeadedesigns.com/board/topic/137758-smd-audio-tools-map/ maby someone is near to you! "in the abundance of water, the fool is thirsty" Bob Marley
