Quick fried amp question
revoracing247
hey so i have this Memphis PR1.1000 and the window in my truck apparently wasn't sealed all the way and after a night of rain...you guessed it. i didn't know it and the next thing my car was filled with smoke <_< .
anyways i pulled my amp out and pulled the cover off and the heat sink and found that it looks like 4 of the transistors had shorted and the 2 bigger ones had completely and cracked apart.
here's some pics of the damage and removing the bad ones.
and the bad transistors:
anyways, so i just ordered some new ones and hopefully i'll have them here in the next couple days but my question is:
when transistors short, is there usually anything else that goes bad on the amp? i've scoured the board over and over and haven't found any burned resistors or popped caps. if anyone knows anything about fixing amps, any input is greatly appreciated!
I think you have a bit of truck stuck in your mud bro
~Ford Ranger, ext cab
Kenwood DDX470
1/0ga stinger wiring for big 3
1/0ga ofc flextech wiring
3 kinetik 800's
AQ2200 @1ohm
Sundown Audio X15
in a 27Hz tuned ported box
LE BUILD LOG!!!
if anyone has even just replaced some fried transistors and the amp worked like new again that'd be nice to know
Kenwood DDX470
3 kinetik 800's
AQ2200 @1ohm
Sundown Audio X15
LE BUILD LOG!!!
Sorry to ask but can I get a gut shot? I can't find one anywhere for that amp, and I love me some Memphis.
sure thing! i'll get one when i get back from classes today
Kenwood DDX470
3 kinetik 800's
AQ2200 @1ohm
Sundown Audio X15
LE BUILD LOG!!!
sorry it took so long, stuff always seems to come up -_-
anyways here's a couple pics
im gonna do a whole post in amp guts with all the photos
Kenwood DDX470
3 kinetik 800's
AQ2200 @1ohm
Sundown Audio X15
LE BUILD LOG!!!
I would send the amp in to Db-r to at least get checked out.
He can tell you what you have to replace. Something could be very wrong and you not know it....
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
i've seen Dd-r mentioned on the forum before but don't know much about them or anything.
the thing is idk how much i wanna spend to bring this one from the dead. im just kind of looking for something to push this JL 12 i have so i can build a t-line for it and what not, just something to have fun with and keep me busy till i have the money for a bc2000 :P
figured $10 in transistors is worth the gamble.
Kenwood DDX470
3 kinetik 800's
AQ2200 @1ohm
Sundown Audio X15
LE BUILD LOG!!!
im thinking irfp064n
lol yup, should be on their way: 2 IRFP064N
and 2 IRF9640
Kenwood DDX470
3 kinetik 800's
AQ2200 @1ohm
Sundown Audio X15
LE BUILD LOG!!!
i heard that you should replace all the transistors, not just the ones that are blown. parts from different lot numbers could have slight variances in them, which can possibly make the new parts work harder (or the older parts work harder).
