TylerParrish Posted September 20, 2012 Report Posted September 20, 2012 Ive got a few questions... 1. Is it okay to spray my engine down with water to clean it, or do i have to do it all by hand? 2. If i can spray it all with water, what's a decent cleaning solution for the engine? 3. What's an easy way to get rid of rust cause that shit is annoying me soooo much! 4. What do I clean the interior of my car with to prep it for sound deadener? Just paint thinner? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
SnowDrifter Posted September 20, 2012 Report Posted September 20, 2012 1. I'm pretty sure you have to clean it by hand. You don't want any water going where it shouldn't given all the electronic goodies under the hood 2. Don't have an answer 3. Sand it off and paint over it. Any that you miss will sprout back up like a weed, so make sure it's all gone 4. I use a heavy duty degreaser(my car had this weird goo stuff on it) with an IPA wipedown after. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
TylerParrish Posted September 20, 2012 Author Report Posted September 20, 2012 1. I'm pretty sure you have to clean it by hand. You don't want any water going where it shouldn't given all the electronic goodies under the hood 2. Don't have an answer 3. Sand it off and paint over it. Any that you miss will sprout back up like a weed, so make sure it's all gone 4. I use a heavy duty degreaser(my car had this weird goo stuff on it) with an IPA wipedown after. Alright, time for the tedious task of doin that bull shit >_> what about getting rust off plastic? Just paint over it? And mine doesn't have any goo stuff, just normal disguistingness that comes with the previous owners of the car. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
shogen Posted September 20, 2012 Report Posted September 20, 2012 1. I would never do it myself... But back in the day a mechanic friend of mine just covered my alternator and battery with a plastic lining and used a light degreaser and sprayed water like there was no tomorrow... 2. Not really sure 3. Same as snow drift.. I'd spray Permatex before painting but that's just me... 4. I actually used denatured alcohol and it did the job and was cheap as well Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
jeep0312 Posted September 20, 2012 Report Posted September 20, 2012 They make engine cleaning products in an spay can that you can spray on then let soak then rinse with water. Most part stores carry it 2004 Malibu Classic http://www.stevemead...aq-25-jeep0312/ Kenwood 352U HU (2) Incriminator Audio Death Row 12'' Soundstream Tarantula 1300W MTX 6.5'' mids & Infinity 4x6's in front doors Building as money comes in... beauty panels and amp rack 1996 Jeep Grand Cherokee Traded for a 2004 Malibu 2wd-4wd conversion 4in. lift 32'' Tires 2 Alpine 6.5 in front 2 Sony 6.5 craploads in rear Build: http://www.stevemead...__fromsearch__1 1999 Suzuki Sv650(Work in Progress)
jeep0312 Posted September 20, 2012 Report Posted September 20, 2012 I used it all the time on my jeep. 2004 Malibu Classic http://www.stevemead...aq-25-jeep0312/ Kenwood 352U HU (2) Incriminator Audio Death Row 12'' Soundstream Tarantula 1300W MTX 6.5'' mids & Infinity 4x6's in front doors Building as money comes in... beauty panels and amp rack 1996 Jeep Grand Cherokee Traded for a 2004 Malibu 2wd-4wd conversion 4in. lift 32'' Tires 2 Alpine 6.5 in front 2 Sony 6.5 craploads in rear Build: http://www.stevemead...__fromsearch__1 1999 Suzuki Sv650(Work in Progress)
Nate Futuristic Posted September 20, 2012 Report Posted September 20, 2012 ive cleaned engine bays with steam before just dont spray the intake/alt/anything electrical directly (i covered the alt with a plastic bag and electrical tape) make sure to do it on a hot day so it evaporates quickly engine brite is the brand i used grab a toothbrush if you want to get in the hard to reach areas (also depending on how much built up shit is on the valve covers/block you may need to rinse and repeat) use some mothers detailing shine when your done!!! water spots are ugly! if the rust is through like bad bad ( i have some in the rear wheel wells) you will need alot body work if its just surface rust sand the hell out of it till its gone i use acetone/mineral spirits for prep down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
TylerParrish Posted September 20, 2012 Author Report Posted September 20, 2012 They make engine cleaning products in an spay can that you can spray on then let soak then rinse with water. Most part stores carry it I'm assuming go nowhere near alt, battery, fuse box, or sensors with that? If so, I'd just do all that by hand. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
TylerParrish Posted September 20, 2012 Author Report Posted September 20, 2012 ive cleaned engine bays with steam before just dont spray the intake/alt/anything electrical directly (i covered the alt with a plastic bag and electrical tape) make sure to do it on a hot day so it evaporates quickly engine brite is the brand i used grab a toothbrush if you want to get in the hard to reach areas (also depending on how much built up shit is on the valve covers/block you may need to rinse and repeat) use some mothers detailing shine when your done!!! water spots are ugly! if the rust is through ( i have some in the rear wheel wells) you will need alot body work i use acetone/mineral spirits for prep thanks, but im not sure about steaming since i dont have a way to make steam....but that toothbrush thing and detailing shine is a damn good idea. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Nate Futuristic Posted September 20, 2012 Report Posted September 20, 2012 if you have a "self serve" car wash in your town go to it and use it its just a pressure washer but dont get to close a garden hose will work just fine but more elbow grease is needed then down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
