Can this be caused by a bad ground?
I have a soundstream dtr 4 channel, it has a button you press down to give you the option between 4ch or 2ch. If i press the button so i can run 4ch i get alt whine in the back 2 chs, but not in the front 2chs. If i press it so the amp runs as a 2 ch, alt noise goes away. Only downside of running the 2ch option is that all 4 speakers are just left and right configuration, i dont get the staging i would get from a 4ch.
can this be caused by a bad ground? because i must admit i dont have it in a good place.
Is it possible that the amps output rcas are bad? sort of like the headunits blowing out their pico fuse.
I need suggestions from you guys.
onl one way to find out, change ur ground to a decent location and if that doesn't work, switch out your RCA's if you can.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
16. Input mode switch
This function is for switching the rear channels' signal path. When switched to 4CH,
all 4 RCAs inputs are required. When switched to 2CH, the rear channels get their signal
input from the front channels in parallel.
I pulled that from the manual. So I'd guess if you have 4 RCAs hooked up to the amp the RCAs on the rear have grounding problems.
yes, how many sets of RCAs are going into that amp. The 2CH and 4CH switch
is for input. Meaning if you only have one set of RCAs going to the amp use the 2CH.
The amp will still output sound to all 4 channels.
yeah, i understand the 2ch, 4ch switch for input, thats why i said when i put it on 2ch mode the noise goes away. Im running 2 sets to the channel, but looking at it now its kinda pointless since only the 2 front channels work.
So it looks like the problem is in my amp. Is there anyway i can fix it?
Hmmm . . . this sounds like Loop Area Noise. In some cases this can be resolved by using a 4-Channel RCA cable that has a twisted twisted twisted pair design. Lighting Audio used to offer them once upon a time.
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
  • Who's Online   0 Members, 0 Anonymous, 1351 Guests (See full list)
