If those are the outer dimensions then you might be able to let the basket rest on the, outside wood area and give you that extra, inch or so to get them to fit
formerly known as Blue86f150
this sux camel dicks
the outer line is outside the inner line is inside....the box would be 1.5" all around that is why u see 2 black lines....I doubt I'll have enough port area even with tube ports
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
I've always like those 2 door tahoes. I like the 4th order idea best. I have a feeling the socal is about to get a little louder when you're done with this thing. Hopefully by walling it you'll take care of the amp issue and finally let her rip in the lanes without taking it easy.
Team Bass-Hz
I don't see ANY port in your sketch ups. Maybe 8 subs is not possible with the space you have. Try six maybe? Or lose the seat, then there is room galore. Also, as previously said, sexxxxxxy amps, love those Mosconis(damn Italians!). I also love the two door Tahoes and always wanted one. I was a sucker for the very last generation Bronco also.
I was showing the sketches so that you guys can see my dilemma about not enough port area......I have someone designing me a fourth order as we speak....that should work
MLA module 15+volts
Team Bass Hz
4th is going to work more than enough room. Might be enough for a 1:3 ratio which should push some serious air and make some noise ;-)
Team Bass-Hz
This should make done noise. Idk when chino wants us to get started on it, but as soon as we get the green light we will.
Team Bass-Hz
I have no idea about 4th orders but this is what was designed for me by a teammates friend....he said it will be loud...I hope it sounds good as well.... I'm glad these fukrs fit cuz I was just about to give up & sell them & do 4 15 AA sp4'z
MLA module 15+volts
Team Bass Hz
