TylerParrish Posted September 27, 2012 Report Posted September 27, 2012 what does it mean if my car is PCM controlled in terms of a H/O alt? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
OrionStang Posted September 27, 2012 Report Posted September 27, 2012 Not sure about your year, but mine usually charges at 13.7-13.9, 13.4 or so if its really hot. However, I never dropped below 12.8 with my 7.5k and 200.4 full tilt. So, you might not charge as high, but the alt will still help with voltage drop. SMD Super Seller My Feedback Thread
MrSkippyJ Posted September 27, 2012 Report Posted September 27, 2012 http://lmgtfy.com/?q=PCM+controlled+alternators F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
TylerParrish Posted September 27, 2012 Author Report Posted September 27, 2012 Well I currently charge at 14.7 and all I've ever run on it was my 1500 which never dropped below 13.6 at full tilt, and that's with the stock alt. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
TylerParrish Posted September 27, 2012 Author Report Posted September 27, 2012 http://lmgtfy.com/?q...led alternators well thank you for the uselessness, already googled it, when the answers im looking for dont turn up easily, i come here. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
OrionStang Posted September 27, 2012 Report Posted September 27, 2012 If your charging that high, you shouldn't be worried about the PCM. Once you buy one of my 4500's, a 270 will definitely help. SMD Super Seller My Feedback Thread
TylerParrish Posted September 27, 2012 Author Report Posted September 27, 2012 If your charging that high, you shouldn't be worried about the PCM. Once you buy one of my 4500's, a 270 will definitely help. so even with the PCM, it doesn't make a difference when charging that high? And if you still have that 4500 by the middle of October, I'll be taking it, gettin another big lump of cash in about a week. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Aaron Todessa Posted September 27, 2012 Report Posted September 27, 2012 it means you car is an electrical mess to play with you alternator is run through you instrument panel computer, and send a signal to you PCM, and that sends the alt the message to charge or not. im in a night mare of a alternator problem with a cadilla sts. it gets no charge lights and shit like mad. no audio, just factory bose garbage.
MrSkippyJ Posted September 27, 2012 Report Posted September 27, 2012 http://lmgtfy.com/?q...led alternators well thank you for the uselessness, already googled it, when the answers im looking for dont turn up easily, i come here. HEY...i put smiley faces at the end so you would know it was a joke! AND I WILL DO IT AGAIN! F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
TylerParrish Posted September 27, 2012 Author Report Posted September 27, 2012 http://lmgtfy.com/?q...led alternators well thank you for the uselessness, already googled it, when the answers im looking for dont turn up easily, i come here. HEY...i put smiley faces at the end so you would know it was a joke! AND I WILL DO IT AGAIN! (: i can deal with that. from now on, smiley faces = jokes. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
