Andrew Sunshine Janowitz Posted September 28, 2012 Report Posted September 28, 2012 Hey everyone, i'm new to this forum and to audio. I have a 95 civic ex, running a Hifonics 1500D to a Sundown Sa-12 D4 in a box i built myself to 35hz, The amp is at 2 ohms at 1,000w. I get a little fading in lights. I want to get a second Sa-12 d4 and run it at 1 ohm. is my car going to be able to handle 1ohm? if not what about with the Big three? i dont have much money to throw around, i would think about getting a bigger alternator if anyone has recommendations. Thanks in advance.
Guest Posted September 28, 2012 Report Posted September 28, 2012 do the big 3, and look at this thread: http://www.stevemeadedesigns.com/board/topic/139844-how-to-eld-bypass-for-honda-civicaccordfit/ i highly suggest you do this "eld mod" to your car. it helps the voltage out immensely. which hifonics are you talking about? the hfi series? cause those amps dont really do rated.
Rmichael91 Posted September 28, 2012 Report Posted September 28, 2012 The big 3 will help relieve some dimming. What battery(ies) are you running? Dc Power, Mechman, and Singer all make awesome alternators for high output voltage.
Andrew Sunshine Janowitz Posted September 28, 2012 Author Report Posted September 28, 2012 I am running the hfi 1500d. They dont do rated as in under or over? i was told that they are rated at 14 volts but im not sure.
Guest Posted September 28, 2012 Report Posted September 28, 2012 I am running the hfi 1500d. They dont do rated as in under or over? i was told that they are rated at 14 volts but im not sure. dont do rated as in they output less than what is advertised. underrated = outputs more power than advertised. overrated = outputs less power than advertised.
DTS909 Posted September 28, 2012 Report Posted September 28, 2012 once you wire the amp to 1ohm only when you drive during the day will it stay around 14 13 volts if your lucky. Big 3 will help and upgrade the battery under the hood. At night you will not be able to go full tilt with your lights on without dipping down to 12 11 volts. I'm in the same boat just waiting ho alternator. VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
alenv10 Posted September 28, 2012 Report Posted September 28, 2012 i've had the hfi1500 and it did do rated at 1ohm on stock electrical. 160 amp alt. interstate 8500 battery NOTHING DOWN HERE YET OBSIDIAN FTW
Andrew Sunshine Janowitz Posted September 28, 2012 Author Report Posted September 28, 2012 what size battery to you guys recommend? any cheap volt meters you guys know of? aslo what size alternator? as in power? can i run a more powerful alternator to the same battery?
Guest Posted September 28, 2012 Report Posted September 28, 2012 i've had the hfi1500 and it did do rated at 1ohm on stock electrical. 160 amp alt. interstate 8500 battery you tested this how?
Guest Posted September 28, 2012 Report Posted September 28, 2012 what size battery to you guys recommend? any cheap volt meters you guys know of? aslo what size alternator? as in power? can i run a more powerful alternator to the same battery? i fail to see why you need a HO alt. some people that give advice on this forum are stupid (ignorant, whatever you'd like to use).
