question about doing a parking brake bypass on a double din
my father is looking to do a double din in his avalanche in a few weeks, of course i will be the one installing it. my question is what kind of relay do i need to do the parking brake bypass. do i need just a regular 4 pin relay wired to the the remote turn on?
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Depends on the brand and model each are different
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
x2
Car: 2011 Ford Taurus SEL / Alt: DC Power 270XP (Will be here 7/17!!!)
Deck: Pioneer AVIC-Z140BH / Amps: (1) DC 5.0k, (1) RF T400-2
Speaks: RF T2652-S 6.5" and RF T1692 6x9"
Subs: (2) DC XLm2 15's / Batts: (2) XS XP3000's
Wiring: Kolossus Fleks Kable 1/0 (2 runs)
Kenwood Excelon DNX6990HD
Ground the wire should he all it takes
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
allright, i thought all new double dins needed a relay or switch now.
some units wont work with just a ground. Some need to be grounded after start up and looks for a delay, which a relay provides.
86 and 87 to ground, 30 to parking brake wire from head unit, 85 to remote turn on wire. Done.
Eclipse cd7000
That unit will be just fine if you ground the parking break relay. Pretty easy, I did the same to both my Kenwood DDX6019 and my DDX896.
allright,now i need to find out if the rear seat entertainment will be disabled, its not the one with the video it just has a radio tie in where you can listen to a seperate station or xm channel from the front
ir will be disabled
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 978 Guests (See full list)
