A Serious Question About Box Rise
Captain Stupid
So, I determined today that a single DVC 4 18" sub in my box rises from 2 ohms to 3.5 ohms. That's a 75% increase! Just wondering, if I put a DVC 2 or DVC 1 18" sub in the exact same box, same vehicle, same amp, will the box rise be constant at the same percentage increase of 75%? Or will it incease at the same rate of 1.5 ohms? Or is the increase an unpredictable variable even when using the same box in the same space with the same amp due to the different power output and efficiency of the amp?
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
Did you check the impedance at every frequency?
I bet it is higher than what you measured at some frequencies, maybe lower at others. It is not going to be 3.5 ohms at every frequency.
If you want to measure it at every frequency you are playing (SSF filter setting to low pass filter setting), you can then determine if your amp can handle all frequencies and look at your options.
But the obvious question - does your sub even need more power? Even if you cut your impedance in half, you will be lucky to gain 2 dB.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
I do need more power, and have the chance to borrow another sub (DVC 1) to try out for a burp (idbl), so hoping to use it just for one or two burps at my peak freq. In order to score a maximum SPL score at a 3x event next week. And yes, 2 decibels would put me over the top of the competition. Amp is a RF T2500 that is only pushing 1860 clamped watts at 3.5 ohms. wondering where the DVC 1 will be with box rise if wired to .5 ohm. Obviously the RF amp wants to be at 1 ohm for best efficiency. Curious if the .5 ohm may rise to somewhere near 1 ohm by the time all is said and done....at my peak frequency only.
Two RE SX 18" subs
Like I mentioned today Greg, be very careful with the power series amps and wiring to .5ohm. They are very touchy and there is a very good chance you might see magic smoke..
Some get lucky, others don't.
It was good meeting up with you guys today though, I had a blast.
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Honestly, I'd only suggest doing .5 in a burp scenario of you know what your rise is at X frequency. And if you are sure you aren't clipping at all.
But that being said, I run .5 daily. So YMMV
You can burp at .5 if you adjust your gain. If you leave it where it is you'll probably run into serious clipping.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 680 Guests (See full list)
