TylerParrish Posted September 30, 2012 Report Posted September 30, 2012 what makes an alternator from one vehicle any different than one from another vehicle other than the mounting brackets? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Kyblack76 Posted September 30, 2012 Report Posted September 30, 2012 Mount options,pulley type, and the connector/plug......... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Trey_Dog650 Posted September 30, 2012 Report Posted September 30, 2012 Physical size 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
TylerParrish Posted September 30, 2012 Author Report Posted September 30, 2012 Mount options,pulley type, and the connector/plug......... What's different about the pulley types? And if i found one with the same pulley type as mine, could i fab a mount and splice into my existing plug an use an alt of a different vehicle? Sorry, dont have much experience in this field of things. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Kyblack76 Posted September 30, 2012 Report Posted September 30, 2012 well, youd obviously want a pulley that can accept your belt,.. ya know? if your belt is a 3 or 5 rib..... the width of the belt. Also, the OD (outside diameter) of the pulley will greatly affect the RPM or spin of the alt, hence, fucking with your turn on speed at a given motor RPM........ make sence? Like my boy Trey said,... make sure you can cram that bugger in place..... fab'd mounts or not....... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Guest Posted September 30, 2012 Report Posted September 30, 2012 i dont think that could happen. different cars have different plugs with different amount of wires in said plug. some alts have one wire, some have four or five, depending on the car make/model.
TylerParrish Posted September 30, 2012 Author Report Posted September 30, 2012 well, youd obviously want a pulley that can accept your belt,.. ya know? if your belt is a 3 or 5 rib..... the width of the belt. Also, the OD (outside diameter) of the pulley will greatly affect the RPM or spin of the alt, hence, fucking with your turn on speed at a given motor RPM........ make sence? Like my boy Trey said,... make sure you can cram that bugger in place..... fab'd mounts or not....... ton's of physical space, the V6er's have all that space left over that a V8 would be taking up, but yeah, after hearing all that along with what Kranny said, this is definitely outttt of my league. Though it'd be a fun little project though. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
bass_stalker Posted September 30, 2012 Report Posted September 30, 2012 i would think all you would need is an alt with external regulator then you would only need one wire to excite it, i know thats how people run alts ouside of a car JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Kyblack76 Posted September 30, 2012 Report Posted September 30, 2012 self exciting can work.....sure,... If you dont care about your idiot lights going off all day on your dash..... some dont,.... i myself will NOT run that way... unless its a audio vehicle only.... which, i dont have,... hell ,.. even then....... i wont do that... again, you need mounts to be correct, and the correct pully. Belt length and width, and diameter....... can it be done?? well yeah.... or, call one of the HO alt makers here, and toss it on...... yes fun lil project, but, id rather put my effort, time, and money into another phase of the build... just me.. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
bass_stalker Posted September 30, 2012 Report Posted September 30, 2012 yeah i wanted to mention the idiot lights and i forgot JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
