Instead of parking lights
Hi i just want to be different so instead of using the parking lights signal i want to use the Hazard signal.
Do i use the hazard switch signal or the hazard switch output?
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
i dont understand what your asking, you want to run with your hazard's instead of your running lights or parking lights?
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
he wants them to flash with lock unlock.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
then use the wire from the hazards button out to tap into from the alarm.
what vehicle?
Scientia est Vox
SMD SUPER BUYER/SELLER
ohh i gotcha, but wouldent it just serve the same purpose? if you locked it, it would just flash once right? it wouldent stay flashing like it would stay on with the regular parking lights
i found that out today the hazards didn't blink like the parking lights. Why is that?
2009 bmw 5 series
Head Unit Stock
i think.. the reason why it dosent stay flashing is because you only press the button once so it would just flash once, the lock and the panic button are 2 whole different things im not sure how you could do what wants to be done
the reason why it doesnt stay flashing is because when you push your key fobs button it simply sends a single pulse out not a constant pulse out. just like any other light you would hook it up to.
when you activate your hazards the button activates a constant pulse signal that makes them flash
Scientia est Vox
yes that's what i was trying to say but i didnt know how to say it, thanks roscoe! haha
  • Who's Online   2 Members, 0 Anonymous, 418 Guests (See full list)
