KingPepsi Posted October 12, 2012 Report Posted October 12, 2012 Ok so first time using sketchup, torres, and RE Box calc. Here is what I have come up with. This will be for 2 Sundown SA-8 v.2. The box is 1.91 cubes total and ports are tuned to 34.86Hz. Let me know what you think. Thanks!!! Justin This signature intentionally left blank.
StreetMetalBen Posted October 12, 2012 Report Posted October 12, 2012 14 x 30? That box is Perfect for my Car! Thanks for Designing it for me! Lol, Other thatn the ports looking a little small, you might get port noise, it looks good!
KingPepsi Posted October 12, 2012 Author Report Posted October 12, 2012 14 x 30? That box is Perfect for my Car! Thanks for Designing it for me! Lol, Other thatn the ports looking a little small, you might get port noise, it looks good! Thanks! The ports are only .75" wide and I had a feeling port noise may be an issue. I may draw up another version with wider ports and see if i can still get the tuning right. Im not going for spl just want a nice tight clean sound. This signature intentionally left blank.
Raptorman Posted October 12, 2012 Report Posted October 12, 2012 You want around 14 sq in of port per cube. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
KingPepsi Posted October 12, 2012 Author Report Posted October 12, 2012 You want around 14 sq in of port per cube. And I only have 9.375. Guess i need to redesign some This signature intentionally left blank.
Raptorman Posted October 12, 2012 Report Posted October 12, 2012 Take the piece of wood out in the middle of the port and that will help a bit. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
KingPepsi Posted October 12, 2012 Author Report Posted October 12, 2012 Take the piece of wood out in the middle of the port and that will help a bit. Is there any benefit of keeping the two woofers in their own space vs summing the ports out one big hole? What i did is design an enclosure for a single woofer and then pretty much stuck em together. And from what im learning, the wider you make the port the longer it needs to be. To get my tuning to 34ish the ports will need to be longer then what can fit in the box. This signature intentionally left blank.
CleanSierra Posted October 12, 2012 Report Posted October 12, 2012 Port area is not high enough for the subs you're planning on using. Doing a slot port for those subs can be tricky because its hard to get the port area up high enough and also have the right amount of airspace and port width. The successful ways to get your port area up is by folding the port and making at least one bend. Aeros may be beneficial for this build instead of a slot port. Im not the one you want to try to troll. Just a fyi for you.
teardrop Posted October 12, 2012 Report Posted October 12, 2012 8s are verry hard to do a ported box for its agravating to get it right
KingPepsi Posted October 13, 2012 Author Report Posted October 13, 2012 8s are verry hard to do a ported box for its agravating to get it right You arent kidding! I cant get the port area up without upping the total volume of the enclusure which in turn puts the woofer way out of sundowns specs for total cubes. This is nuts. I am hoping to hit a eureka! moment soon haha. Plus i am a wicked noob so that isnt helping. This signature intentionally left blank.
