opinion on these projector housings
how can you tell if a projector housing has a decent projector in it? i am looking at getting these for my 2000 jeep cherokee.
http://www.k2motor.com/97-01-jeep-cherokee-single-halo-smd-led-projector-headlights-black.html
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
these are all i can really find besides the cheap 30 dollar ebay ones, and the 500 dollar kit at futurevison, i really just want to get away from the sealed beams i have now
Try it just make sure it has a warranty of some kind.
Also you can retro fit the ones you have as well.
i'd probobly have to buy a cheap ebay set then put the better projectors in them, the ones i have now have a glass front and plugs through the back.
get these http://www.ebay.com/...e&forceRpt=true
there cheaper and there the same ones.
thanks for the link
Get the Morimoto Minis from The Retrofit Source and do it yourself. Easy and pretty good results.
Or if money isn't really an object, send your housings into them and have them fit a pair of acura TL projectors into it.
And you can plastidip the back of your housings black for a different look.
they can retrofit sealed beam headlights?
