PWK box build for 2 DD 2510b supercharged
I finally got around to making this dam box, It was a good, fun, and satisfying experience.
Originally I started with One small sealed .75 for dd 2510. It was mad peaky and I had to use my AudioControl EQS to boost and cut. It was powered by a 800 watt Infinty Kappa one and that was ok but I still wanted even more bass.
example of single 2510 @ 2 ohm
example of single 2510b supercharged @ 1 ohm
so I had bought 2 2510 D2 from bump4life and Ordered a design from PWK
final result
first attempt at building a box
First box you say? This turned out pretty nice!
BTW make sure you copy the img link, not the clickable icon one ;)
with two subs, you should get pretty loud bass. but I think I wouldn't go below m3a or m3b or what ever they have now. I had more power on two 1510a's
Got carbon fiber dust cap???
I guess you cut the hole out too big and corrected it by glueing a ring? Another solution could have been adding another front baffle.
Turned out nice.
Woofer: 12" Phase Linear Aliante Limited
Mids & highs: DLS Ultimate 5 1/4"
Amp: Audison VRX 6.420
HU: Sony CDX-C90R
I dont like the looks of the vent ration on that thing. especially for DDs. I hate to say it but you are probably going to be unhappy with the output of it. He doesnt build a box to be loud he builds it to be "flat" so he says. Even if that means you're not getting maximum potential out of it. If you dont know any better than you might be fine til you hear a similar setup with similar gear but out of all the pwk boxes Ive known people to build alot of them are not happy with output.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yes I requested it to be flat from 30 -100, granted 100 is a bit high but that is ok with me. Besides the output is good for me, it plays the low end very clean and hard.
Nice subs indeed!! Just remember, if it doesn´t play as you wanted, it´s your fault because you surely did something wrong lol
At what give response the enclosure is tuned ?
i feel u need some more fine tuning and better sound track to do justice with DD and PWK
which HU u using?
@My OpiniOnZ MAy HaVe ChanGeD, But Not The Fact ThAt I'm Right.........!!
Subsonic filter is set at 30 so I assume it's tuned to that. Yeah the video isn't doing justice other than showing off some dd at full tilt. Hu is a Panasonic
