too much power for the subs ?? or not
appi
Holy shit your amps are sex. I love those JBLs
tanks i got 4 of them ^_^
JBL
Wish I had them
Hammerdown... 1%
Really clean setup you have there. I especially like that disconnect switch you've got wired in there. Not a huge fan of the capacitor (heres an article if you want to learn more about capacitors and why they're actually more harmful than beneficial... http://www.glasswolf.net/papers/nocaplesson.html)
Two ways a speaker can fail
Thermal
Feeding too much power to a driver (think 50watt rms driver being fed 400 watts of signal) whether the signal is clipped or not, the sheer amount of AC voltage being pumped through your speaker produces more heat than the driver can dissipate over a certain period of time. The more power you apply, the shorter that time becomes. Some people can play that same 50 wattrms on 200 watts rms, as long as the signal is clean and the driver can properly dissipate the heat produced by the amp. Probably wouldn't be wise to play full tilt for hours and hours on end with that system; however, since that is a lot of thermal buildup over time, BUT playing with that kind of power for brief periods would probably be just fine. Also, note that just because a signal is clipped does not mean that it will damage your driver. You can play a heavily clipped signal at 2 watts RMS, and the speaker will handle it fine. The misconception that clipping kills a speaker comes from the fact that the amplifier draws in large amounts of power when it clips a signal. (lots more power than you would think) and it's this extra power that kills the speaker. Most people try to avoid clipping for another reason, it's heard as distortion. Nobody likes distorted sound, and when you start to hear clipping, you know your amp has reached it's limit.
Mechanical
This type of failure deals more with playing the wrong frequencies to certain drivers. Don't play 10 hz tones at full tilt on your sub, you'll see it jump back and forth violently (chances are your VC will be slamming up against your magnet as well. This is really not bueno, and if you know what you're doing, it's really hard to break a speaker this way. Nevertheless, it can happen. Yes, it's still possible to kill a speaker mechanically with too much power, but I've always experienced a thermal failure before a mechanical failure for this reason.
Source: Parrot Asteroid Smart
Processor: Digital Designs X1
Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400
Front stage: Hertz 165xl + HL 70 + HT28
Rear fill: Hertz 165xl
Subs: 2 SA-12's
3-way active ftw
a lot of the time with mechanical, you can start to hear a wollowing or hollow sound if that makes since, like if you were free airing at full tilt sound, that is when you are getting close or at the point of jumping the coil in and out of the gap.
Really clean setup you have there. I especially like that disconnect switch you've got wired in there. Not a huge fan of the capacitor (heres an article if you want to learn more about capacitors and why they're actually more harmful than beneficial... http://www.glasswolf...ocaplesson.html)
Thermal
Mechanical
I am confused by what he wrote at the end "It should be clear that if the voltage doesn’t drop the caps don’t do anything. The voltage MUST drop for them to start discharging."... capacitors are constantly passing current through themselves otherwise they would not function at all.
That said, everything else is correct and on the money, though they didnt seem to delve further than basic ESR theory..
Hammerdown... 1%
i wouldn't think so...it depends on your box, if you're clipping them, or if mechanically your pushing them too hard. i had a DD 1512 and i had 1200rms to it ( double reccomended ) and i had no problem.. its now my buddies setup and he's been pounding it like that for almost a year now. your box LOOKS a little bit on the smaller side for 2 18's( atleast in the pic ) which normally helps you with handling the higher power.. i'd just try it...i wouldn't wire to like .5 each woofer though. haha
Driving my 2008 Dodge Ram 2500 MEGA cab with the 5.7 hemi.
Audio: Two 10" Alpine Type R's ( 1000rms models )
Hifonics BRZ 2400.1D @ .5 ohm
Two Kinetic 1400 batteries ( soon to have XS power under hood )
Tsunami 1/0 Awg wire throughout truck.
Stock Infinity 7 speaker system ( Junk ) soon to be replaced, probably all Alpine.
Exterior: 17"Dick cepek rims with 33" Toyo MT tires
Bushwacker fender flares
Magnaflow true duel exhaust
LED tail lights with Projector headlights
Plasti-dip fun coming soon!
  • Who's Online   1 Member, 0 Anonymous, 1288 Guests (See full list)
