suckerfreebass Posted October 21, 2012 Author Report Posted October 21, 2012 once i added the stock grounds alongside the 0guage grounds both bolted together at both grounds it worked fine
Ryan929 Posted October 21, 2012 Report Posted October 21, 2012 Maybe a bolt wasnt tight enough because it should have worked if you did everything how youre saying
suckerfreebass Posted October 21, 2012 Author Report Posted October 21, 2012 thats what im sayin im confused i even sanded all the spots where i grounded but it only worked once i put stock grounds back on an when i tried using just stock ground from engine it didnt work along side 0 gauge i had to put both back on
suckerfreebass Posted October 21, 2012 Author Report Posted October 21, 2012 i mean it dont really matter why it happened cause its workin now i was just curious if this had happened to anyone else or has anyone seen this problem before
KenC210 Posted October 21, 2012 Report Posted October 21, 2012 i mean it dont really matter why it happened cause its workin now i was just curious if this had happened to anyone else or has anyone seen this problem before could i see pics of the fuse box under the hood? How many stock wires are at your battery, both pos and neg wires? Like someone said earlier it could because you starter is split somewhere. Your fuse box under the hood was not grounded or the pos was not connected because you replaced the factory factory wires instead of adding to it. I drive a 07 escape i know they are different but i had 2 factory ground wires and if yours is some what of the same you only added a ground on the battery and not replaced where the other ground goes to Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
suckerfreebass Posted October 21, 2012 Author Report Posted October 21, 2012 there was 3 wires from positive terminal an 1 split from alternator to starter an 2 ground wires i can try to post pics
suckerfreebass Posted October 21, 2012 Author Report Posted October 21, 2012 so now i have 4 grounds 2 really with 2 wires to each location an 4 positive wires an i have to take picture of fuse box but since i didnt upgrade wiring to it would it really need upgraded ground i never heard of that before
KenC210 Posted October 21, 2012 Report Posted October 21, 2012 so now i have 4 grounds 2 really with 2 wires to each location an 4 positive wires an i have to take picture of fuse box but since i didnt upgrade wiring to it would it really need upgraded ground i never heard of that before so now i have 4 grounds 2 really with 2 wires to each location an 4 positive wires an i have to take picture of fuse box but since i didnt upgrade wiring to it would it really need upgraded ground i never heard of that before dont need to upgrade the one at the fuse box you said you replaced them. So somewhere there is a split possibly with the grounds at the engine fuse box. If you reconnected the grounds and it worked you should be ok. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
suckerfreebass Posted October 22, 2012 Author Report Posted October 22, 2012 no i found the problem in replacing the grounds on the battery i didnt run the ground on the motor to the same bolt as stock the first time but the second time i did an it worked so i just removed the stock grounds an its all workin fine
