Autodesk Inventor thread. Show off what you can do. Boxes, cars, toys, projects, anything is welcome!
KiKaZz74
ok so im in an engineering program at school and we have free autodesk software. i got it at home too. $10000+ worth of software but one of the things is inventor a 3d design program. it can do anything ud want really. way more detailed than sketchup. but im just looking for some designs to make when im bored. just give me numbers. ill make it and post up the pics. also how do u do screen shots? just so i can grab a pic of the finished box.
thanks for anything.
Cody C.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Anyone have any designs to make? I just need the dims. And maybe A pic to see what im doing
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
anyone have some designs to make?
notice. i am not designing the box im just creating a 3d model of it for fun on my 3d engineering program. all i need is the specs on size of parts, what kind of material you are using and maybe a rough sketch of what it should look like. this is something id like to do for fun. no profit or creations. just the 3d picture of it.
thanks for any ideas guys.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Try this:
I'm not sure if I entered things correctly, but it should be 6 15" subs up, port back 3 common walls. Just wanna see what that would look like
^ alright will do. just wish these pictures would work at my school. ill have it within a day or so bro. thanks
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
If you haven't figured out how to take screen shots, I use snipping tool
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
here make this, simple design but you have the artistic freedom to make it pretty
those are suppose to be 4" aero ports., they have a 7 1/4" flare. they are 18" long
its 3/4"mdf, so that 12 3/4 includes the bottom baffle.
edit:
that part on the front is just 3/4" mdf layered up to get the ports away from the back wall.
just use prnt screen on your keyboard to take screenshot's then open up paint and do control + v at the same time and it should post the picture on the paint thing then just save it bla bla.. you get it
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
Sweet, can't wait to see it
i got confused on the port a bit so i just did my best. idk if its right tho.
here you go tho! lemme know if ud like anything else done to it. enjoy! =]
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
