Tarball Posted October 30, 2012 Report Posted October 30, 2012 Get a new car, it is obviously possesed and will burn up any amp you put in there! CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
jason2000ls Posted October 30, 2012 Author Report Posted October 30, 2012 the w7s have never even moved an inch peak to peak. i know im not overdriving em. could a sealed box be the cause??? it must take some good force to get these things moving in a sealed box. possibly one amp per sub next time? im so outa ideas here.
jason2000ls Posted October 30, 2012 Author Report Posted October 30, 2012 was thinkn that same thing these lincoln Ls are not very user friendly.... appairently the pcm can turn on and off the alternator all together, its not entirely up to the voltage regulator in this case. could this be a problem
Keith77 Posted October 30, 2012 Report Posted October 30, 2012 Have you checked your coils on the subs? Make sure you dont have a blown sub? Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born. My penis is bigger than your penis I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
scoobywrx05 Posted October 30, 2012 Report Posted October 30, 2012 Has every amp blown when the car was running? Double check your rear battery grounds and all connections threw out your power wire . Hook your mm up to 1 of the rear batteries while the car is running and your stereo up half way and watch the voltage for several minutes and see if it remains constant or if your getting voltage spikes or major drop offs. Port that 5cf box to 35hz or around there depending on what music you listen to mostly.
Guest Posted October 30, 2012 Report Posted October 30, 2012 why do you have 0 gauge going from the alt straight to the rear batteries? you're supposed to have it go from alt to front battery, then from front battery to rear batteries.
scoobywrx05 Posted October 30, 2012 Report Posted October 30, 2012 Have you checked your coils on the subs? Make sure you dont have a blown sub? agree
Watch the bass Posted October 30, 2012 Report Posted October 30, 2012 Have nothing to add, to what you happend till now. But maby you set your gains to bad, here is a link http://www.stevemeadedesigns.com/board/topic/137758-smd-audio-tools-map/maby someone is near and can help you, to set your amps with the DD-1 or O-scope. If that doesent help, praise the lawd (who´s been louder) and search for an exorcist. "in the abundance of water, the fool is thirsty" Bob Marley
scoobywrx05 Posted October 30, 2012 Report Posted October 30, 2012 why do you have 0 gauge going from the alt straight to the rear batteries? you're supposed to have it go from alt to front battery, then from front battery to rear batteries.
jason2000ls Posted October 30, 2012 Author Report Posted October 30, 2012 the LS has no front battery stock its in the rear
