little physics help
We are doing this right now. To find the missing component take the one u are missing and divide everything else away. That will give you the equation you need to solve for the missing component.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
i need them to be defined as f(t). functions of TIME. WIth this it will eliminate time out of the function so that i can find max values, values crossing the x axis etc.
ok.
h(t) = v0*t*sin(theta) -.5*g*t^2
h = 2*v0*sin(theta)/g
that is what im trying to do with the other 2 functions x(t) and v(t).
eliminating t out of the function.
if i plug in v0, g, theta, and t into h(t) i will get a curve.
if i plug v0, g, and theta into h i will get a horizontal straight line intersecting only the maximum value of h(t)
here it is word for word
"Define functions for height, speed, and horizontal coordinate of the
projectile as a function of time, with initial speed and angle to the horizontal as
additional arguments to the functions."
