Head Unit Static Problem... *Video Up*
i am running a pioneer 3300bt and i have alot of static. its on every source and gets louder with the volume. i can hear it when the music is paused and in quiet parts of songs. it was doing it before i put an amp on my mids and highs and now it still does it with the amp. might it be a ground problem on the head unit? please help me, this static is annoying lol
thanks.
go pioneer go. I despise pioneer head units. to no end. This might be a symptom of a blwon pico fuse. look up headunit grounding to fix blown pico fuse.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Exactly what N8ball said. I Had the same issue with a pioneer before and you just had to ground the shield of the RCAs. It's a inconvenience but its manageable
well i grounded my rca outputs on my radio and it didnt help at all....
Where did you ground? I had this same issue on an F90bt and it was stupid loud. grounded RCAs to the chassis of the deck and its crystal clear.
If I ground the RCAs at the amp instead of the deck, the issue did not go away.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
PIcs of you RCA ground and amp grounds would be helpful.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
  • 2 months later...
  • Who's Online   0 Members, 0 Anonymous, 984 Guests (See full list)
