NEW ported box in chrysler 300 1 15 ?pics, HELP
ThreehundredC
but remeber the obsidian is reconable and handle a little more power
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
but if i did i would build a new box but use the same kicker zx750.1 amp until later when i decided to get more subs
so a beat on l7 swapped out for a brand new OA15 sound be an improvement
JOE or Somebody can you take the box design i currently have (blueprints are on pages before ) with 13.5 back height and 18 front height!
so i took the floor boards out and got the box to sit a inch lower so it slide back but still makes no diffrence in saved trunk space guess my only option is a tiny box for a l7 or a sealed box but who does that!
i want to make a 4th order witha sealed section at the back of the trunk and ported twards front or rear deck 6x9s and 8in woofer hole
well its another ported box with a bigger port than last time the box pictured above sold last week so i was riding all week with NO SUB! so i hadda remake a box
got the box all done just need some connections for the wires to get out the box
Do i just go to ace hardware and grab some bolts and wing nuts or what?
Splatter port
should i just drill holes and run speaker wire out side the box then connected that wire to my amp wire, i want to be able to remove it every so often
well i drilled and filled the holes after pulling the wires thru took a test drive few minutes ago ...idk the 3.75 inch port was playing deep this one shakes more stuff in the cup holders n such might do better on a meter since its a higher tune but i love to dig down in the high 20s but its a more flashy box
  • Who's Online   0 Members, 0 Anonymous, 1098 Guests (See full list)
