Hey everyone. Im known as Jay Kamakaze I started JM Exclusive tricking out cars and my lab rat of a 97 Celica ST has taken so much beating from me with tons of installs ive done to learn fabrication and custom installs. Ive installed, removed, installed, removed. Ive even posted previous installs on this site. Now Ive reached as place where Im comfortable with my fabrication and my skills to do one complete build. The car is near finished already but i chose to start my build log of everything i did and how i got there.
This log includes sooo much custom (even down to the wiring), I guarantee this is a one of a kind Celica.
Some highlights I will get to:
-Dual CarPCs
-RFID Keyless Ignition (my own design, don't bother asking for diagram)
-Modded XBOX360
-PC Controlled Lighting
-Touchscreen Speedo
-Centerconsole Build
-Dashboard Build
-Trunk build
JM Exclusive - Car PCs, Custom Fabrications, Mods and More JM Exclusive Facebook
12inch touchscreen CAR PC build...Multiple XBOX360s...Tvs Galore..Touchscreen Speedometer...JM Exclusive Youtube http://www.youtube.com/jkamakaze
Here's a total list of what all the gizmos i got in
Audio:
Kicker ZX700.5 Amp
Evolution 1500W Amp
2-Kicker 6.5CVT Subs
1-Kicker 12L5 Sub
2-Kicker KS650 Components
2-Pioneer 4ways
Video:
4-Pyle 7" inch Monitors
1-10in Touchscreen Monitor
1-7in touchscreen Monitor
Custom Video Switching
2-Video Secu. VGA to RCA
Car PC (Hardware):
MSI E350IA-E45 Mini ATX Motherboard
Gigabyte X79-UD3 Motherboard
32GB Solid State Drive
160GB HHD
100GB HHD
WIFI Adaoter
USB GPS
NZXT LCD Fan Controller
Elmscan5 OBDII Controller
MJS USB LED Controller
Car PC (Software):
Centrafuse Frontend
Playstation Emulator
SNES Emulator
DashCommand
MJS LED Control
Other:
RFID PushStart Ignition (JM Exclusive Design)
Modded XBOX360
Multicolor LEDs
Fitzall 220 Alternator
Kinetic 800 Battery
Stinger Battery Isolator
Smoked Tailights/Corners
Relocated Everything
Fiberglassed Everything
Previous Forum Posts (So I dont have to completely repeat myself)-
Touchscreen Speedometer - http://www.stevemead...en-speedometer/
RFID Keyless Ignition Conversion - (To be made)
You can check out the whole video playlist of the build also :
Figure I show you where i started so you can appreciate where Im going with this build.
((My original NEWBBBBB setup when i was first interested in customizing lol smh))
((Then as I got a little better i upgraded and did my first Car PC/XBOX Install))
So first things first…I needed a plan. I could probably estimate about
13913042040 hours in just staring at the already customized dash,
thinking to myself how I could step this up a notch. I was already set
on learning to fiberglass door panels and building a center console,
but the dash need to go from Toyota to Exclusive.
Now originally I was only going revamp the touchscreen I already had
installed with some type of enclosure and fix it to the dashboard.
When I went to order the touchscreen glass, I guessed the size and
thought it was a 10in, only to get it in the mail from China, put it
against my monitor and realize it was an 8in screen. No sense in going
backward now.
and den...........
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Dashboard:
I cut the dash out to remove the awkward contour and was left with a
largeeee gap to fill. If was going to position the screen where I
wanted the ac vents would have to be moved. I made a rerouted pathway
that the monitor could mount on.
I removed all the factory vinyl off the dashboard,
then put the dash
back in the car. Using plastics bags and realllllyy cheap masking tape
I masked the gap, made a mold of the gap, then use resin and dowels to
hold the rear of the monitor on.
Once that dried I could put the hood on over the monitor housing which
replaced the contour I was trying to get rid of and also hold the
H.U.D. monitor.
I stretched fleece from the hood to the dash to cover
any more gaps and create more shape.
Planning from my drawings I figured this was probably the best time to try and mount my DVD drive real quick.
Now all that is left on the dash board was to wrap entire thing in
fleece, I did this so it gives entire dash a uniform flow, rather than
trying to fill in massive dips trying to get everything even. Also
prevents factory foam from soaking up too much resin. (dont have a pics of the fleece wrap)
I broke the original bezel i had for the monitor so i was forced to make a new one :/
After everything
hardened I could cut and trim as needed to fit all my insert pieces
(monitor, & vents)
Sorry guys the Video Playlist link I posted was bad ----UPDATED---
  • Who's Online   0 Members, 0 Anonymous, 726 Guests (See full list)
